D00681
D00681
    DURATOOL
D00681 数据手册
Fume Absorber Specifications Voltage : 220-240V AC 50Hz Power Consumption : 23W ESD safe(Coating) ESD : Electro static discharge Absorption Capacity : 1M3/min(Max) Overall dimension : 200mm(W) × 270mm(H) × 168mm(D) Weight : 1,400g Accessories Activated-carbon Filter(2 pieces) Black colour Size :130mm × 130mm ×10mm Part Number Table Description Part Number Fume Absorber, Bench Top ESD EU D00681 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 31/10/17 V1.0
D00681
PDF文档中包含以下信息:
1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款同步降压DC/DC转换器,具有高效率和低噪声的特点。
3. 引脚分配:共8个引脚,包括输入、输出、地和控制引脚。
4. 参数特性:输入电压范围为4.5V至38V,输出电压可调,最大输出电流为3A。
5. 功能详解:详细介绍了器件的工作原理和功能,包括同步降压转换、软启动、过流保护等。
6. 应用信息:适用于需要高效率和低噪声电源转换的场合,如便携式电子设备、通信设备等。
7. 封装信息:采用SOIC封装。
D00681 价格&库存
很抱歉,暂时无法提供与“D00681”相匹配的价格&库存,您可以联系我们找货
