D03125
D03125
    DURATOOL
    DURATOOL - D03125 - Handheld Digital Multimeter, DC Current, AC/DC Voltage, Continuity, Diode, Resis...
D03125 数据手册
3½ Digital Multimeter Features •  •  •  •  •  •  •  •  •  •  3½ digital multiple with 7 sections LCD display Press the BACKLIGHT button to turn on the backlights Function and range switch Data hold button Direct current voltage measurement Alternating voltage measurement Diode, resistor, temperature and circuit on-off measurement 1999 maximum display value Low voltage indication 9V battery, NEDA 1604 or 6F22 powered Specifications Fuse Power Maximum display value Over-range Indication Polarity Display Operating Temperature Storage Temperature Low Voltage Indication Dimension Weight Max. Voltage between Input   and the ground Contents : F1 250mA/250V F2 10A/250V : 9V battery, NEDA 1604 or 6F22 : 1999 : “1” : “ - ” for negative polarity : 0°C to +40°C : -10°C to +50°C :“ ” on the display : 138mm×69mm×31mm : 170g : CATII 600V : Multimeter, One pair of probes, Instruction manual, One 9V battery NEDA 1604 6F22. Direct Current Voltage Measurement Range Resolution Accuracy 200mV 100μV ±0.5% of reading, ±3 digits 2V 1mV ±0.5% of reading, ±3 digits 20V 10mV ±0.5% of reading, ±3 digits 200V 100mV ±0.5% of reading, ±3 digits 600V 1V ±0.8% of reading, ±5 digits Overload protection: 200mV range: 250V DC or RMS; The rest ranges: 600V DC or RMS. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 20/06/22 V1.0 3½ Digital Multimeter Direct Current Measurement Range Resolution Accuracy 20μA 0.01μA ±1% of reading, ±3 digits 200μA 0.1μA ±1% of reading, ±3 digits 2mA 1μA ±1% of reading, ±3 digits 20mA 10μA ±1% of reading, ±5 digits 200mA 100μA ±1.5% of reading, ±5 digits 10A 10mA ±3% of reading, ±10 digits Overload protection: F1 200mA/250V Fuse F2 10A/250V Alternating Voltage Measurement Range Resolution Accuracy 200V 100mV ±1.2% of reading, ±10 digits 600V 1V ±1.2% of reading, ±10 digits Overload protection: 600V DC or RMS Frequency range: 40Hz to 400Hz Display: Average (effective value of sinusoid) Resistor Range Resolution Accuracy 200Ω 0.1Ω ±0.8% of reading, ±5 digits 2kΩ 1Ω ±0.8% of reading, ±2 digits 20kΩ 10Ω ±0.8% of reading, ±2 digits 200kΩ 100Ω ±0.8% of reading, ±2 digits 2MΩ 1kΩ ±1.0% of reading, ±5 digits Maximum open circuit voltage: 3.2V Overload protection: 250V DC or RMS Diode and Circuit On-Off Measurement Range Description When the on-resistance is smaller than (70±30)Ω, the built-in buzzer will sound. Displays the approximate diode positive voltage. Overload protection: 250V DC or RMS. AC. Temperature Measurement Range °C Resolution 1°C Measurement Accuracy -20°C to 0°C ±10% Range, ±2 digits -0°C to 400°C ±1.0% Range, ±3 digits 400°C to 1000°C ±2.0% Range Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 20/06/22 V1.0 3½ Digital Multimeter Operation •  Plug the instrument in and check the 9V battery. If it is low the “ ” symbol will display, meaning the battery needs replacing. •  The besides the probe jack indicates that the input voltage or current should not exceed the specified limits, in order to protect the internal circuit. •  Before measurement, turn the function/range switch to the desired range. Direct Voltage Measurement •  Insert the red probe into the “VΩmA” jack and the black one into the COM jack. •  Turn the function/range switch to the range of and connect the probe to the power supply or load to be measured. The polarity touched by the red probe will be on the display. •  Overload protection: 250V DC or AC (RMS) Part Number Table Description Part Number 3½ Digital Multimeter D03125 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 20/06/22 V1.0
D03125 价格&库存
很抱歉,暂时无法提供与“D03125”相匹配的价格&库存,您可以联系我们找货
