D03464
D03464
    DURATOOL
    DURATOOL - D03464 - Soldering Station, 30 W, 240 Vac, Plug UK, 480 Deg C
D03464 数据手册
Soldering Stations Features Specification •  •  •  •  •  Heater : PTC, 160°C to 480°C(320 to 896°F) Voltage : AC 220 to 240V 50Hz Power : 30W(Max 130W) Digital temperature control by knob with LED display(°C/°F) Easier way to achieve °C/°F conversion by an individual switch below the knob Heats up to 400 °C quickly in only 50s. User-friendly with integrated parts: soldering iron stand+copper cleaning ball+cleaning sponge+roll stand for solder wire. Soldering iron stand and holder. With solder feeder and sponge. Safety outer metal holder. Holds up to 2 lb roll of soldering wire. A special sponge for tip cleaning. Diagram Part Number Table Description Part Number Soldering Stand and Dispenser D03462 Soldering Mat, 297mm × 210mm × 5mm Silicone D03463 Soldering Station, 30W, 240V, UK D03464 Spare Iron For D03464 ZD-415G Spare Tip, Pointed N9-16 Spare Tip, Chisel, 2mm N9-26 Spare Tip, Chisel, 3mm N9-36 Spare Tip, Chisel, 4mm N9-46 Spare Tip, Knife N9-56 Spare Tip, Screwdriver N9-66 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 09/07/21 V1.0
D03464 价格&库存
很抱歉,暂时无法提供与“D03464”相匹配的价格&库存,您可以联系我们找货
