CTT-8440-01
CTT-8440-01
    DURATOOL
    DURATOOL - CTT-8440-01 - CRIMP TOOL
CTT-8440-01 数据手册
Insulated Terminal Crimp Tool Features: •  •  •  •  •  •  •  Heat Treated Dies Heat Treated Frame Components Black Oxide Finish on Frame & Dies Full-Cycle Ratchet Controlled Release Ratchet Set to Release when A 15-35 lb. Load is applied Approx. 1 3/4” from End of Handles Orange Moulded Textured Plastic Grips Note: 0.01 Max. Jaw Misalignment Permissible. Shim Frame Jaws to Correct any Misalignment. Gaging Information Nest Conductor Insulation H W H W 22 - 18 Red 0.104/0.096 0.22 014/0.13 0.24 16 - 14 Blue 0.112/0.104 0.24 0.17/0.16 0.26 12 - 10 Yellow 0.154/0.145 0.31 0.21/0.2 0.35 Part Number Table Description Part Number Insulated Terminal Crimp Tool CTT-8440-01 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 17/08/12 V1.0
CTT-8440-01
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型放大器,具有高输入阻抗和低输出阻抗,适用于高速光隔离数据传输。
3. 引脚分配:EL817有8个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作电压范围为3.3V至5.5V,输入电流小于1mA,输出电流大于10mA。
5. 功能详解:EL817内部包含光敏三极管和晶体管,实现光电信号转换和放大。
6. 应用信息:适用于工业控制系统、通信设备和医疗设备等领域。
7. 封装信息:EL817采用8脚DIP封装。
CTT-8440-01 价格&库存
很抱歉,暂时无法提供与“CTT-8440-01”相匹配的价格&库存,您可以联系我们找货
