D02155
D02155
    DURATOOL
    Molded
D02155 数据手册
Tool Kit – 152 Pcs Specifications Product Type Product Dimension (L × W × H) : General Tool Kit : 46.5mm × 37mm × 16.5mm Kit Contents Contents Material Quantity 1/4" Sockets: 4 * 4.5 * 5 * 5.5 * 6 * 7 * 8 * 9 * 10 * 11 * 12 * 13mm CRV 12 1/2" Sockets: 10 * 11 * 12 * 13 * 14 * 15 * 16 * 17 * 18 * 19 * 21 * 22 *23 * 24 * 27mm CRV 15 1/4" Extension Bars: 2" * 4" * 5" CRV 4 1/2" Sliding Bar: 10" CRV 1 1/4" Sliding Bar: 110mm CRV 1 Universal Joint: 1/2" * 1/4" CRV 2 1/2" Spark Plug: 16mm * 21mm CRV 2 Ratchet Handle: 1/2" & 1/4", 72T CRV 2 Spinner Handle: 1/4" CRV 1 7" Scissor CRV 1 6" Knife CRV 1 6" Long Nose Plier CRV 1 6" Combination Plier CRV 1 6" Diagonal Cutting Plier CRV 1 10" Water Pump CRV 1 8" Crimping Plier CRV 1 Hex Key: 1.5 * 2 * 2.5 * 3 * 4 * 5 * 6 * 8 * 10 CRV 9 8" Adjustable Wrench CRV 1 Combination Wrench: 8 - 9 - 10 - 11 - 12 - 13 - 14 - 15 - 17 - 19mm CRV 10 Screwdrivers: 5 * 75mm, 4 * 100mm, 6 * 100mm, 6 * 125mm, 5.5 * 125mm CRV 9 100 - 250V Tester CRV 1 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 12/06/18 V1.0 Tool Kit – 152 Pcs Contents Material Quantity Carbon Steel 5 CRV 5 Carbon Steel 1 6" Chest Saw Aluminum 1 300g Hammer - 1 5mm Tape Measure - 1 Fasteners - 60 10Y Tape - 1 Aluminum case - 1 Wood Drill: 4 - 5 - 6 - 8 - 10mm 0.8mm Nail Punch, 3mm Center Punch, 5mm Pin Punch, 3mm Taper Punch, 10mm Cold Chisel 10" Wood Chisel Part Number Table Description Part Number General Tool Kit, 152 Pcs D02155 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 12/06/18 V1.0
D02155 价格&库存
很抱歉,暂时无法提供与“D02155”相匹配的价格&库存,您可以联系我们找货
