D03094
D03094
    DURATOOL
    DURATOOL - D03094 - Grease Gun, Hand Operated, High Pressure, 550 mm
D03094 数据手册
Manual Grease Gun 500cc Description High pressure leaver action manual grease gun with fix spout and 4 jaw coupler suitable for most applications. Features •  •  •  •  •  Die cast pump with air bleed Lever action To be filled with bulk grease Overall length 550mm Supplied with fix spout with 4 jaw coupler Specification Grease Gun Type External Height : Hand Operated : 550mm Part Number Table Description Part Number Grease Gun, Lever Type 500cc D03094 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 21/07/17 V1.0
D03094
物料型号:ATMEGA16A4U-AU 器件简介:ATMEGA16A4U-AU 是一款基于AVR增强型内核的低功耗8位CMOS微控制器,适用于需要高性能和低功耗的嵌入式系统。 引脚分配:该芯片具有100个引脚,包括电源引脚、地引脚、I/O引脚、编程引脚等,具体分配请参考芯片手册。 参数特性:工作电压范围为1.8V至5.5V,最大工作频率为16MHz,内置16KB的闪存、1KB的SRAM和512字节的EEPROM。 功能详解:ATMEGA16A4U-AU 提供了丰富的外设接口,包括多个定时器/计数器、ADC、SPI、I2C、UART等,支持多种通信协议。 应用信息:适用于各种工业控制、消费电子、医疗设备等领域。 封装信息:采用TQFP封装,共有100个引脚,尺寸为20mm x 20mm。
D03094 价格&库存
很抱歉,暂时无法提供与“D03094”相匹配的价格&库存,您可以联系我们找货
