D02333
D02333
    DURATOOL
D02333 数据手册
4Pc Pin Vice Set Features: •  •  •  •  Vices for holding small tools, drills, taps etc. Knurled body Hallow shaft for holding long items Capacity: 0 - 1mm, 0.8 - 1.5mm, 1.3 - 3.1mm, 3.0 - 4.8mm Part Number Table Description Part Number Pin Vice Set, 4Pc D02333 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 28/08/14 V1.0
D02333
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40至+85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源和信号隔离。
6. 应用信息:适用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP-6封装。
D02333 价格&库存
很抱歉,暂时无法提供与“D02333”相匹配的价格&库存,您可以联系我们找货
