37 6104
37 6104
    DURATOOL
    DURATOOL - 37 6104 - Caster, Swivel, Light Duty Applications, 55 kg, 100 mm
37 6104 数据手册
Castors 37 4101, 37 4102, 37 4103 and 37 4104 37 5101 37 5102 Features: • Offers a grey ‘non-marking’ rubber tyre on a black nylon centre including thread guards which is available with plain bore The wheels can be fitted in the following castor housings: • • 37 5104 37 6101, 37 6102, 37 6103 and 37 6104 37 8101, 37 8102 and 37 8103 Top plate swivel, fixed and swivel with foot brake Threaded stem swivel and threaded stem with foot brake 37 9101, 37 9102, 37 9103 and 37 9104 Recommended Uses: This wheel type is recommended for light duty applications Specifications: In accordance with ISO 2175. Defines castor and / or wheel application appropriate with environmental conditions-load, speed of use, temperature, floor condition and cycle time Type : Plain bearing bore www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 07/06/12 V1.1 Castors 37 6101, 37 6102, 37 6103 and 37 6104 37 5101, 37 5102 and 37 5104 37 4101, 37 4102, 37 4103 and 37 4104 37 8101, 37 81032 and 37 8103 37 9101, 37 9102, 37 9103 and 37 9104 Dimensions : Millimetres Specification Table Description Wheel Diameter (D) Thread Width (b) Castor, Apparatus, Swivel Top 50 20 Castor, Apparatus, Swivel Top 60 Castor, Apparatus, Swivel Top 80 Castor, Apparatus, Swivel Top 100 Overall Plate Hole Height Dimensions Spacing (H) (A × B) (a × b) 68 55 × 55 40 × 40 85 24 106 60 × 60 121 Hole Width (e) 45 × 45 6 Offset (E) Carrying Capacity (kg) Part Number 25 35 37 4101 21 50 37 4102 25 32 55 37 4103 37 4104 Dimensions : Millimetres www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 07/6/12 V1.1 Castors Description Wheel Diameter (D) Thread Width (b) Overall Plate Hole Height Dimensions Spacing (H) (A × B) (a × b) Castor, Apparatus, Fixed Top 50 20 68 Castor, Apparatus, Fixed Top 60 24 85 Castor, Apparatus, Fixed Top 100 24 121 Description Wheel Diameter (D) Thread Width (b) Overall Height (H) Stem Diameter (C) Stem Length (F) Plate Diameter (C) Castor, Apparatus, Swivel* 50 20 66 8m 15 35 Castor, Apparatus, Swivel* 60 Castor, Apparatus, Swivel* 80 55 × 55 40 × 40 60 × 60 45 × 45 Hole Width (e) 6 104 12 m 25 Part Number 35 37 5101 50 37 5102 55 37 5104 Offset (E) Carrying Capacity (kg) Part Number 25 35 37 6101 21 50 37 6102 - 83 24 Carrying Capacity (kg) Offset (E) 41 25 37 6103 55 Castor, Apparatus, Swivel* 100 121 32 37 6104 *Threaded stem swivel castor Wheel Thread Overall Plate Hole Hole Carrying Offset Pedal Diameter Width Height Dimensions Spacing Width Capacity (E) Length (D) (b) (H) (A × B) (a × b) (e) (kg Description Castor, Apparatus, Swivel Top** 50 Castor, Apparatus, Swivel Top** 60 Castor, Apparatus, Swivel Top** 80 20 24 68 85 106 55 × 55 40 × 40 60 × 60 45 × 45 6 Part Number 25 76 35 37 8101 21 84 50 37 8102 25 91 55 37 8103 **Swivel castor with foot brake Description Wheel Thread Overall Stem Stem Plate Diameter Width Height Diameter Length Diameter (D) (b) (H) (C) (F) (C) Castor, Apparatus, Swivel*** 50 Castor, Apparatus, Swivel*** 60 Castor, Apparatus, Swivel*** 80 Castor, Apparatus, Swivel*** 100 20 66 8m 15 35 83 24 104 12 m 124 25 41 Offset (E) Pedal Length Carrying Capacity (kg) Part Number 25 76 35 37 9101 21 84 50 37 9102 25 91 32 95 55 37 9103 37 9104 Dimensions : Millimetres ***Threaded stem castor with foot brake Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 07/06/12 V1.1
37 6104 价格&库存
很抱歉,暂时无法提供与“37 6104”相匹配的价格&库存,您可以联系我们找货
