DT000236
DT000236
    DURATOOL
    DURATOOL - DT000236 - Antistatic Storage, Bin, 10.83 ", 275 mm, 11.22 ", 285 mm, 15.35 "
DT000236 数据手册
Multiusage Circulation Box Specifications External Size (L×W×H) Internal Size (L×W×H) Surface Resistance Weight : 390mm × 285mm × 275mm (15.35" × 11.22" × 10.83") : 360mm × 250mm × 255mm (14.17" × 9.84" × 10.04") : 103-109Ω : 1.995kg Part Number Table Description Part Number Antistatic Storage Conductive, Bin DT000236 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 10/04/18 V1.1
DT000236
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离器件。
2. 器件简介:EL817是一种光隔离器件,用于隔离输入和输出电路。
3. 引脚分配:EL817有5个引脚,分别为A、B、C、D和E。
4. 参数特性:工作电压为5V,工作电流为10mA,隔离电压为2.5kV。
5. 功能详解:EL817通过光电耦合实现信号隔离,保护电路不受干扰。
6. 应用信息:EL817广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-8封装。
DT000236 价格&库存
很抱歉,暂时无法提供与“DT000236”相匹配的价格&库存,您可以联系我们找货
