DT000364
DT000364
    DURATOOL
    DURATOOL - DT000364 - Torque Wrench, Preset Slipping, 2-10 N.m, 0.25 " Drive, 185 mm Overall Length
DT000364 数据手册
1/4” Drive Adjustable Torque Wrench with Reversible Ratchet Features •  Reversible ratchet •  Quick release Specifications Parameter DT000364 Tool Style DT000365 Wrench Overall Length 8.3″ (210mm) 9.8″ (248mm) Drive (Ratchet) Size 1/4″ (6.35mm) Gear (Ratchet) Teeth 64 Teeth Torque Range Graduation 3 to 15 N-m 5 to 25 N-m 31 to 128 lb-in 53 to 212 lb-in 0.1 N-m Torque Tolerance 0.2 N-m ± 3% Material Specifications Ratchet Ratchet Head Body Handle : Chrome Molybdenum Alloy Steel AISI (SAE) 4140 : Chrome Vanadium Steel SAE (AISI) 6140 : Low Carbon Steel 1018 : Low Carbon Steel 1018 Part Number Table Description Part Number 1/4″ Drive Adjustable Torque Wrench with Reversible Ratchet, 210mm DT000364 1/4″ Drive Adjustable Torque Wrench with Reversible Ratchet, 248mm DT000365 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 31/08/18 V1.0
DT000364 价格&库存
很抱歉,暂时无法提供与“DT000364”相匹配的价格&库存,您可以联系我们找货
