D01449
D01449
    DURATOOL
D01449 数据手册
PCB Spacer Support Specifications: Overall Length Spacer Material Bore Dia. Nom Colour Thread Length Overall Length : 3mm : Nylon 6.6 : 4mm : White : 10mm : 10mm Dimensions : Millimetres Part Number Table Description Part Number PCB Spacer Support, Nylon 6.6, Natural D01449 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 24/01/13 V1.0
D01449
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一款高速光耦器件,具有高输入输出隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚(发光二极管阳极),2脚(发光二极管阴极),3脚(输出晶体管集电极),4脚(输出晶体管发射极),5脚(输出晶体管基极),6脚(Vcc)。 4. 参数特性:主要参数包括输入电流为5mA,输出电流为50mA,隔离电压为5000V,响应时间为250ns。 5. 功能详解:EL817通过内部发光二极管和光敏三极管实现电信号的光电隔离,具有高速传输和高隔离性能。 6. 应用信息:广泛应用于数字通信、高速数据传输、工业控制系统等领域。 7. 封装信息:EL817采用DIP-6封装形式,具有较好的机械强度和热稳定性。
D01449 价格&库存
很抱歉,暂时无法提供与“D01449”相匹配的价格&库存,您可以联系我们找货
