D03460
D03460
    DURATOOL
    DURATOOL - D03460 - Soldering Iron and Gun Kit, Soldering Gun, Iron, Magnifier, Desoldering Pump, Ir...
D03460 数据手册
Quick Heat-up Soldering Gun Set Features The tool kit includes •  With a fingertip trigger. •  Easy for soldering with the light bulb at the head of the gun. •  •  •  •  •  •  •  •  •  •  Specifications Voltage : AC 110-130V 60Hz AC 220-240V 50Hz Power : 100W 150W Operation •  •  •  •  •  Quick heat-up soldering gun Soldering iron 50W Desoldering pump Soldering wire 5g Box size: 350mm × 270mm × 70mm Iron stand Soldering tip Soldering aid tool Helping hand with magnifier Rosin Before using the gun, make sure the voltage matches with the product’s specifications. Prior to operation, clean any dirt, rust or paint from the area to be soldered. Choose the suitable tip for the material you plan to solder. Plug it in and turn on the switch. After operation, unplug it and put the gun in a safe place out of children’s reach. Attention! To avoid overheat, please always press the trigger to turn it on for 12S, then release the trigger to turn it off for 48s. Warning •  •  •  •  The appliance is not a toy, and must be kept out of children’s hands. Before cleaning the appliance, always unplug it. Unscrewing the housing is not permitted. This appliance is not intended for use by persons (including children) with reduced physical, sensory or mental   capabilities, or lack of experience and knowledge, unless they have been given supervision or instruction concerning use of the appliance by a person responsible for their safety. •  Children should be supervised to ensure that they do not play with the appliance. •  If the supply cord is damaged, it must be replaced by the manufacturer, its service agent or similarly qualified persons in order to avoid a hazard. Part Number Table Description Part Number Soldering Gun Set, 240V, UK D03460 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 09/07/21 V1.0
D03460 价格&库存
很抱歉,暂时无法提供与“D03460”相匹配的价格&库存,您可以联系我们找货
