DT000085
DT000085
    DURATOOL
    DURATOOL - DT000085 - Soldering Iron Stand, For Soldering, Desoldering or Rework PCBs
DT000085 数据手册
Soldering Iron Stand Rigid metal structure Rubber feet of the base ensure stability Features •  •  •  •  The adjustable circuit board holder is ideal for clamping PCB for soldering, desoldering or rework. Features 2 adjustable grips on a retractable stand to accommodate various board sizes. The adjustable clamps allow the PCB to rotate 360 degrees and stay set in any position. The base of this rigid metal stand features four rubber feet to ensure stability. Part Number Table Description Product Size Max. Holding Size Product Weight Part Number Soldering iron Stand 30cm×16.5cm×12.5cm 20cm × 14cm 450g DT000085 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 05/06/17 V1.0
DT000085
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压为3-5.5V,工作电流为0.1mA,接收频率为38kHz。
5. 功能详解:EL817可以接收红外信号并输出TTL电平信号。
6. 应用信息:EL817广泛应用于电视、空调等红外遥控设备。
7. 封装信息:EL817采用SOP-8封装。
DT000085 价格&库存
很抱歉,暂时无法提供与“DT000085”相匹配的价格&库存,您可以联系我们找货
