3090-250-11-01
3090-250-11-01
    DURATOOL
3090-250-11-01 数据手册
Hand Ribbon Cable Cutter L=255 Ì Hand cable cutter with built-in cable guide Ì Gives clean perpendicular cuts to cable with up to 64 conductors (82mm wide) 28AWG Note: The flat platen is not replaced as it is plastic, but acquires a slot over the cutter’s life which does not normally affect the efficiency of the blade. If it does affect the cutting efficiency, replace the whole tool. 208852 Price Each Order Code Cutter Spare Blades 147-824 150-077
3090-250-11-01 价格&库存
很抱歉,暂时无法提供与“3090-250-11-01”相匹配的价格&库存,您可以联系我们找货
