Roof Filter Fan RFP 018 Series
300m³/h, 500m³/h
Very low noise
Minimal depth in enclosure
High through-flow air volume
High reliability
Time-saving installation and mat exchange
Ventilating
Photo: Art. No. 01860.0-00
Roof filter fans find use in enclosures and housings, from which warm air has to be diverted to
lower the internal temperature. These low-noise roof filter fans are used to expel warm air from
within the enclosure which has been generated by the stray power of the components and
so protects the internal devices from overheating. To exchange the filter mat the hood can be
easily opened without tools. The roof exit filter provides passive ventilation.
Photo: Art. No. 01861.0-00
26
Axial fans, ball bearing
service life 50,000h at 25°C/77°F (65% RH)
Connection
3-pole clamp for 2.5mm², clamping torque 0.8Nm max.
Case
plastic according to UL94 V-0, light grey;
Roof Filter Fan (01860.0-xx)
fan body aluminium, rotor plastic
weather proof and UV light resistant according UL746C (f1)
Filter mat
G3 acc. to DIN EN 779, filtering degree 85%
Filter material
synthetic fibre with progressive construction, temperature
resistant to 100°C, self-extinguishing class F1;
moisture resistant to 100% RH, reusable - cleaning by
washing or vacuuming
Operating / Storage humidity
Roof Filter Fan (01861.0-xx)
max. 90 % RH (non-condensing)
Prot. type / Protection class
IP32 / I (earthed)
Approvals
UL intended; (230V only: VDE)
Important note: For reasons of pressure compensation the roof filter fan must always be operated in
combination with a passive intake filter (e.g. Art. No. 11803.0-00) or another filter fan (e.g. Art. No. 01803.0-00).
Hole centers
Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/
buyer in its final application.
04.08.2010
Technical Data
Enclosure cut-out
Art. No.
Operating
voltage
01860.0-00
01861.0-00
01860.0-02
01861.0-02
230VAC, 50Hz
230VAC, 50Hz
120VAC, 60Hz
120VAC, 60Hz
Air volume,
Current
Average noise level Depth in
free flow consumption (DIN EN ISO 4871) enclosure
300m³/h
500m³/h
345m³/h
575m³/h
68W
64W
60W
85W
55dB (A)
67dB (A)
55dB (A)
67dB (A)
52mm
107mm
52mm
107mm
Enclosure
cut-out
Weight
(approx.)
Operating /
Storage temperature
250 x 250mm + 0.4
250 x 250mm + 0.4
250 x 250mm + 0.4
250 x 250mm + 0.4
3.3kg
2.6kg
3.3kg
2.6kg
-10 to +70°C (+14 to +158°F) / -40 to +70°C (-40 to +158°F)
-25 to +70°C (-13 to +158°F)
Roof Exit Filter REP 118 Series
Art. No.
11860.0-00
Depth in enclosure
11mm
Enclosure cut-out
250 x 250mm + 0.4
Weight (approx.)
1.0kg
Filter mat
Protection type
IP32
Filter Mat FM 086
Filter mat
G3 (1 packing unit = 3 pcs.)
282 x 282mm
Art. No. 08613.0-01
++ STEGO UK Ltd. + Unit 12, First Quarter Business Park + Blenheim Road + Epson, Surrey KT19 9QN + England + info@stego.co.uk + www.stego.co.uk ++
很抱歉,暂时无法提供与“01861.0-02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2695.36138
- 5+2629.97290
- 12+2590.81687
- 25+2550.41118
- 50+2488.31347
