1 TECHNICAL
1
DATASHEET
FILTER FAN PLUS
FPI/FPO | 223 x 223 mm
>>New air-flap outlet technology for
high airflow
>>Easy mounting
>>Protection type test/Environmental
rating by independent testing institutes
(VDE and UL)
>>Two systems for optimal airflow
(FPI/FPO)
>>Standard enclosure cut-out sizes
(5 sizes)
>>One filter mat
Filter fans are used to provide an optimum climate in enclosures and cabinets with electrical/electronic components.
The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure
thus expelling heated internal air. The resulting airflow prevents formation of localised hot pockets in installations
and protects electronic components from overheating.
The Filter Fan Plus series uses a new air-flap outlet technology for the air outlet and thus reaches a high degree
of airflow. A ratchet mechanism is used for mounting and provides high stability and tightness. Depending on the
application there are two systems that are available – the FPI or FPO system. The FPI system is a standard installation
with a filter fan in the lower part of the enclosure which ensures that fresh air is fed into the enclosure (airflow
direction "In"). This system consists of a filter fan and exit filter. Whereas in the FPO system, the filter fan is located
in the upper area of the enclosure to avoid heat buildups (airflow direction "Out"). The FPO system is composed of
an intake filter and exit filter fan. The Filter Fan Plus series has been designed for indoor use.
TECHNICAL DATA
SYSTEM FPI
Axial fan, ball bearing
service life L10 at +40 °C (+104 °F): min. 56,000 h
rotor metal
Connection
3-pole clamp for 2.5 mm², clamping torque 0.8 Nm max.
Casing, hood, flaps
plastic according to UL94 V-0, light grey;
UV light resistant according to UL746C (f1)
Enclosure cut-out
223 x 223 mm
Mounting frame
4 built-in ratchet braces for mounting
(6 notches for wall thickness 1 — 4 mm).
Additional use of screws possible if needed1.
Filter mat
G3 acc. to DIN EN 779, average arrestance Aa 84 %
Filter material
synthetic fibre with progressive construction,
temperature resistant to +100 °C, self-extinguishing class F1,
moisture resistant to 100 % RH, reusable
Operating temperature
-25 to +65 °C (-13 to +149 °F)
Storage temperature
-40 to +70 °C (-40 to +158 °F)
Operating/Storage humidity
max. 75 % RH (non-condensing)
Protection type/Protection class
IP54 / I (earthed)
Environmental rating UL/NEMA
UL TYPE 12 / NEMA 12
Approvals
VDE, UL File No. E234324, EAC
Note
other voltages on request
warm
Air outlet
through flaps
cold
Air intake
through filter mat
with fan
1
Drilling marks for screw mounting are indicated on mounting frame.
AIRFLOW DIRECTION "IN": FILTER FAN FPI 018
Art. No.
Operating voltage
Air volume,
free flow
01873.0-30
AC 230 V, 50/60 Hz
305 m³/h
01873.9-30
AC 115 V, 50/60 Hz
332 m³/h
Air volume
with exit filter
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Depth in
enclosure
Weight
(approx.)
Filter mat
227 m³/h
300/340 mA
64 W
64 dB
147 mm
2.4 kg
G3
238 m³/h
600/700 mA
81 W
67 dB
147 mm
2.4 kg
G3
AIRFLOW DIRECTION "IN": EXIT FILTER FPI 118
Art. No.
Depth in enclosure
Weight (approx.)
Air outlet
11873.0-00
46 mm
0.6 kg
15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUKTKATALOG - STEGO
2 TECHNICAL
2
DATASHEET
SYSTEM FPO
warm
Air outlet through
flaps with fan
AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018
Art. No.
Operating voltage
Air volume,
free flow
01883.0-00
AC 230 V, 50/60 Hz
536 m³/h
01883.9-00
AC 115 V, 50/60 Hz
581 m³/h
Air volume
with exit filter
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Depth in
enclosure
Weight
(approx.)
air outlet
281 m³/h
300/340 mA
310 m³/h
600/700 mA
64 W
65 dB
147 mm
2.4 kg
air-flaps
81 W
68 dB
147 mm
2.4 kg
air-flaps
AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118
Art. No.
Depth in enclosure
Weight (approx.)
Filter mat
11883.0-30
25 mm
0.5 kg
FILTER MAT FM 086
Filter class
215 x 215 mm
Average arrestance Aa
1 packing unit
Art. No. 08636.0-00
84 %
5 pieces
TECHNICAL DRAWINGS
46
25
26
FPI 018
257
147
FPI 118
26
26
223
26
223
223
147
223
257
FPO 018
FPO 118
cold
Air intake
through filter mat
很抱歉,暂时无法提供与“01883.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1674.26383
- 5+1624.03789
- 12+1573.82237
- 25+1540.33147
- 50+1506.83016
- 国内价格 香港价格
- 1+1752.447401+227.37860
- 3+1577.220083+204.64300
- 10+1383.5294410+179.51180
