02100.0-30
02100.0-30
    STEGO
    STEGO - 02100.0-30 - VARIOLINELAMP, DAYLIGHT WHT, 1080LM, 11W
02100.0-30 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com LED 021 Movement sensor and screw fixing LED 022 On/off switch and magnet fixing www.stegousa.com VARIOLINE LAMP LED 021/022 >>High luminous flux >>Integrated power unit >>Durable and maintenance-free LED technology >>Daisy chain >>On/off switch or movement sensor >>Magnet or screw fixing TECHNICAL DATA LED 021/022 side view L1 L2 1.72in LED 021/022 magnet or screw fixing Power consumption max. 11 W/16 W Operating voltage AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) Luminous flux 1,080 Lm/1,730 Lm Lamp type LED, angle of radiation 120° light color: daylight, color temperature: 6,500 K Service life 60,000 h at +20 °C (+68 °F) Connection 2-pole connector with snap lock AC: max. 2.5 A / AC 240 V, color: white Mounting magnet fixing or screw fixing (M5), torque 2 Nm max. Casing plastic, translucent Dimensions see drawings Weight approx. 0.2 kg/0.3 kg Operating/Storage temperature -30 to +40 °C (-22 to +104 °F) / -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP20 / II (double insulated) Mounting options: The lamps are available with magnet fixing for easy positioning in any steel cabinet or enclosure. A classic is the LED 021/022 with screw fixing. With a total rotation angle of 360° it provides perfect illumination. Note: The lamp must not be used for household lighting. View of magnet fixing View of screw fixing 1.72in LED 021 (Size 1) L1 = 15.6 in L2 = 14.6 in LED 022 (Size 2) L1 = 23.4 in L2 = 22.4 in Size 1: L1 = 400 mm Size 2: L1 = 600 mm Art. No. Magnet fixing Art. No. Screw fixing Art. No. Magnet fixing Art. No. Screw fixing 02100.0-30 02100.0-00 02200.0-30 02200.0-00 On/off switch VDE UL 02110.0-30 02110.0-00 02210.0-30 02210.0-00 PIR movement sensor1 VDE UL 02120.0-30 02120.0-00 02220.0-30 02220.0-00 without switching option VDE UL ¹ approx. 5 min. fixed switch-on duration Switch Approvals 15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The LED 021/022 Varioline is a powerful and compact LED lamp for use in enclosures. Its LED tube emits more than 1,000/1,700 Lm at only 11 W/16 W power consumption, thereby illuminating even very large enclosures in their full depth and height. The glare-free, 360° rotatable LED tube uses Mid-power LEDs with a service life of 60,000 h. The emitted daylight color of 6,500 K provides safety for the user by a natural and non-fading color reproduction. www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com ACCESSORIES LED 021/022 Connectors and cables for electrical connection are not included in the delivery of the LED 021/022. These parts can be ordered separately. Sets, consisting of lamp and accessories, are available on request. Likewise, custom cables are available on request. LAMP-SET WITH FEMALE CONNECTOR Varioline LED enclosure lamps are also available as a set including the connector Art. No. 264057. Simply add -0003 to the article number of the required lamp. For example: 02100.0-30-0003 FEMALE / MALE CONNECTORS 1 Photo: Male connector, Art. No. 264058 Art. No. Model Voltage type Color Use for Wire cross-section1 Approvals 264057 female connector AC white power input 0,5-2,5 mm2 (AWG 14-20) VDE + UL 264058 male connector AC white power output 0,5-2,5 mm2 (AWG 14-20) VDE + UL applies to rigid and stranded wire. Wire end ferrules must be used when connecting with stranded wires CONNECTION CABLE WITH FEMALE CONNECTOR AND OPEN END Photo: Connection cable, Art. No. 244356 1 Art. No. Model Length Voltage type Color Use for 244356 connection cable 2 x 1.5 mm² with female connector 2.0 m AC connector: white; cable: white power input Approvals² VDE 244357 connection cable 2 x AWG 16 with female connector 2.0 m AC connector: white; cable: white power input VDE + UL Approvals² ² applies only to the individual components (cable and connectors) EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN CONNECTION Photo: Extension cable, Art. No. 244358 2 Art. No. Model Length Voltage type Color Use for 244358 extension cable 2 x 1.5 mm² with 2 connectors 1.0 m AC connectors: white; cable: white daisy chain VDE 244359 extension cable 2 x AWG 16 with 2 connectors 1.0 m AC connectors: white; cable: white daisy chain VDE + UL ² applies only to the individual components (cable and connectors) CONNECTION EXAMPLE 2 1 0.75in 0.75in 0.75in This illustration shows the LED 021/022 lamp in a daisy chain application. The lamps are conveniently connected via connection plugs - up to 8 lamps max. can be daisy-chained this way. The snap lock connectors ensure a stable electrical connection even if subjected to heavy vibration. The connection example shows a AC 230 V application, using the following cables: connection cable with female connector, Art. No. 244356 (1); daisy chain extension cable with 2 connectors, Art. No. 244358 (2). Female/male connectors are also available to assemble cables in non-standard lengths. 15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Photo: Female connector, Art. No. 264057
02100.0-30 价格&库存
很抱歉,暂时无法提供与“02100.0-30”相匹配的价格&库存,您可以联系我们找货
  • 1+945.681651+122.91010
库存:20
