02811.0-01
02811.0-01
    STEGO
02811.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com TOUCH-SAFE PTC FAN HEATER CS 028 / CSL 028 | 150 - 400 W >>Compact size >>Quiet operation >>DIN rail or screw mount available >>Heating power adjusts to ambient temperature The CS 028 / CSL 028 fan heater prevents formation of condensation and provides an evenly distributed interior air temperature in enclosures. The heater is connected using the internal terminal connectors. The surface temperatures on the accessible side surfaces of the housing are minimized as a result of the heater design. The small size of the CS 028 / CSL 028 make it ideal for use in enclosures where space is at a premium. TECHNICAL DATA View: back side Screw mount PTC resistor - temperature limiting Surface temperature 150 W / 250 W: max. 122 °F (50 °C) except upper protective grill 400 W: max. 149 °F (65 °C) except upper protective grill measured at 68 °F (20 °C) ambient temperature Axial fan, ball bearing service life 40,000 h at 104 °F (40 °C) Air flow, free blowing CS 028: 8 cfm (13.8 m³/h) CSL 028: 32 cfm (54 m³/h) @ AC 120 V; 26 cfm (45 m³/h) @ AC 230 V Connection 2-pole terminal AWG 14 max. (2.5 mm²) with strain relief, torque 0.8 Nm max. Housing plastic, UL 94V-0, black Mounting screw mount or clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type II (double insulated) / IP20 Approvals UL File No. E234324 (all), GOST TR (all), VDE (AC 230 V only) Note other voltages available upon request Heating Power (W) DIN clip Heating element Wiring example CS(L) 028 Fan Heater Thermostat Ambient Temperature Part No. - DIN mount Part No. - screw mount Series Operating voltage Heating capacity¹ Max. current (inrush) Dimensions (H x W x D) Weight (approx.) 02800.0-00 02800.0-01 CS 028 AC 230 V, 50/60 Hz 150 W 12 A 2.95 x 2.56 x 3.54” (75 x 65 x 90 mm) 10.6 oz. (300 g) 02800.9-00 02800.9-01 CS 028 AC 120 V, 50/60 Hz 150 W 6A 2.95 x 2.56 x 3.54” (75 x 65 x 90 mm) 10.6 oz. (300 g) 02810.0-00 02810.0-01 CSL 028 AC 230 V, 50/60 Hz 400 W 15 A 3.54 x 3.35 x 4.37” (90 x 85 x 111 mm) 17.6 oz. (500 g) 02810.9-00 02810.9-01 CSL 028 AC 120 V, 50/60 Hz 400 W 9A 3.54 x 3.35 x 4.37” (90 x 85 x 111 mm) 17.6 oz. (500 g) 02811.0-00 02811.0-01 CSL 028 AC 230 V, 50/60 Hz 250 W 9A 3.54 x 3.35 x 4.37” (90 x 85 x 111 mm) 17.6 oz. (500 g) 02811.9-00 02811.9-01 CSL 028 AC 120 V, 50/60 Hz 250 W 6A 3.54 x 3.35 x 4.37” (90 x 85 x 111 mm) 17.6 oz. (500 g) ¹ at 68 °F (20 °C) ambient temperature 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Photo: Fan Heater CSL 028
02811.0-01 价格&库存
很抱歉,暂时无法提供与“02811.0-01”相匹配的价格&库存,您可以联系我们找货
  • 1+929.79945
  • 25+918.76078
  • 50+897.16248
  • 100+866.76449
库存:9
02811.0-01
  • 1+1061.008441+136.96730
  • 5+943.099165+121.74620
库存:7
02811.0-01
  • 1+990.72841
  • 5+880.64747
库存:7
