30TECHNICAL
30
HEATING
DATASHEET
>>High DC heating performance
>>Integrated thermostat or hygrostat
(optional)
>>Small hysteresis
>>Integrated switch module
>>Screw fixing
>>Optical indicator (LED)
The compact high performance fan heater prevents formation of condensation and frost and provides an evenly
distributed interior air temperature in enclosures with electric/electronic components. The fan heater is available
with an integrated electronic thermostat or integrated electronic hygrostat. The model with thermostat is available
with internal or external sensor. The fan heater with integrated hygrostat is equipped with an external sensor. The
external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and
humidity. The DCR 030 was designed as a stationary unit for the bottom of the enclosure. For wall fixing the fan
heater DCR 130 is recommended.
100
TECHNICAL DATA
166
105
145
130
Heating element
high performance cartridge
Temperature safety cut-out
with automatic reset and second-tier one shot fuse to protect
against overheating in case of fan failure
Heater body
extruded aluminium profile
Axial fan, ball bearing
airflow 160 m³/h, free flow
service life 50,000 h at +25 °C (+77 °F)
Connection
2-pole „Push-In“ connection clamp stranded wire1 1.5 mm²
(AWG 16) with strand relief; max. 2.5 mm² (AWG 12)
Casing
plastic according to UL94 V-0, black
Mounting
screw fixing (M5), torque 2 Nm max., washers have to be used
Fitting position
vertical airflow (air outlet up)
Dimensions
166 x 145 x 100 mm
Weight
approx. 1.3 kg
Operating temperature
-20 to +75 °C (-4 to +167 °F)
Storage temperature
-40 to +80 °C (-40 to +176 °F)
Operating / Storage humidity
max. 90 % RH (non-condensing)
Protection type / Protection class
IP20 / II (double insulated)
Approvals
UL File No. E234324, VDE, EAC
Note
other versions (heating capacities, setting ranges) as well as
operating voltage DC 48 V on request
¹ When connecting with stranded wires, wire end ferrules must be used.
Connection diagram
M
INT
EXT
23.05.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
HIGH-PERFORMANCE FAN HEATER
DCR 030 | DC 24 V, DC 56 V – 200 W to 800 W
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
Art. No.
Model
Operating voltage
Heating capacity
Recommended pre-fuse T
(time-delay)
Setting range3
temperature / humidity
03092.1-12
Thermostat with
internal sensor
DC 24 V
200 W
25.0 A
-20 to +40 °C
03092.1-13
Thermostat with connector
for external sensor²
DC 24 V
200 W
25.0 A
-20 to +40 °C
03097.3-12
Thermostat with
internal sensor
DC 56 V
800 W
25.0 A
-20 to +40 °C
03097.3-13
DC 56 V
800 W
25.0 A
-20 to +40 °C
03092.1-03
Hygrostat with connector
DC 24 V
200 W
25.0 A
40 to 90 % RH
03095.3-03
DC 56 V
600 W
25.0 A
40 to 90 % RH
² The external sensor needs to be ordered separately.
³ Switch difference temperature: 3 K (±1 K tolerance) at +25 °C (+77 °F), 50 % RH; switch difference humidity: 4 % RH (±1 % tolerance) at +25 °C (+77 °F), 50 % RH.
ACCESSORIES
The external sensor is not included in the delivery of the DCR 030. It can be ordered separately.
EXTERNAL SENSOR
The external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and humidity.
Art. No.
Length
267071
1m
267072
2m
267126
3m
31 31
HEATING
STEGO - PRODUCT
CATALOGUE
TECHNICAL
DATASHEET
很抱歉,暂时无法提供与“03092.1-12”相匹配的价格&库存,您可以联系我们找货
