Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
VENT PLUG
DA 084
>>High degree of protection (IP55)
>>Easy to install
TECHNICAL DATA
1
Mounting
PG 29 thread with union nut
Torque
5 Nm (max. 10 Nm)
Mounting position
vertical1
Material
plastic, UL 94V-0, light grey
weather proof and UV light resistant according to UL746C (f1)
Sealing
NBR gasket
Air Interface
Approx. 1.5 cm²
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Dimensions
Ø 2.58" x 1.2” (Ø 65.5 x 30.5 mm)
Protection type is restricted to IP54 if mounting position is not vertical
Installation
A hole with a diameter of 1.46” (37 mm) is required for mounting. Make sure that the sealing gasket is placed on the outer
side panel of the enclosure. For optimal pressure compensation, it is recommended to use two devices on opposite sides
towards the top of the enclosures.
Part No.
Protection type
Weight (approx.)
08400.9-01
IP55
1.1 oz. (31 g)
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
It has become increasingly important to provide a protected enclosure environment for valuable and crucial
electrical and electronic components. In a tightly closed enclosure, pressure differentials can occur during extreme
temperature variations, such as day/night operation. When this occurs, the risk of dust and humidity ingression into
the control panel increases dramatically. The specially designed DA 084 vent plug permits a controlled change
in pressure and can easily be installed in any enclosure. The vent plug is suitable for the use in enclosures and
electrical cabinets in accordance with DIN EN 62208.
很抱歉,暂时无法提供与“08400.9-01”相匹配的价格&库存,您可以联系我们找货
