267071
267071
    STEGO
    STEGO - 267071 - EXTERNAL SENSOR, 3.28FT
267071 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com HIGH-PERFORMANCE FAN HEATER DCR 130 | DC 24 V, DC 56 V – 200 W to 800 W >>High DC heating performance >>Integrated adjustable thermostat or hygrostat >>Small hysteresis >>Integrated switch module >>Panel or DIN rail mounting >>Optical indicator (LED) TECHNICAL DATA 3.89" (99mm) 2.95" (75mm) 5.91" (150mm) 5.61" (142,5mm) 7.05" (179mm) 6.61" (168mm) Heating element high performance cartridge Overheat protection with automatic reset and second-tier one shot fuse to protect against overheating in case of fan failure Heater body extruded aluminium profile Axial fan, ball bearing service life 50,000 h at +77 °F (+25 °C) Air flow, free blowing 94 cfm (160 m³/h) Connection 2-pole „Push-In“ connection clamp stranded wire1 AWG 16 (1.5 mm²) with strain relief; max. AWG 12 (2.5 mm²) Housing plastic, UL 94V-0, black Mounting clip for 35 mm DIN rail, EN 60715 or M6 screws and washers (not included), torque 2 Nm max. Mounting position vertical airflow (air outlet up) Dimensions 3.9 x 6.6 x 7.0" (99 x 168 x 179 mm) Weight approx. 2.86 lbs. (1.3 kg) Operating temperature -4 to +167 °F (-20 to +75 °C) Storage temperature -40 to +176 °F (-40 to +80 °C) Operating / Storage humidity max. 90 % RH (non-condensing) Protection type / Protection class IP20 / II (double insulated) Approvals UL File No. E234324, VDE, EAC Note other versions (heating capacities, setting ranges) as well as operating voltage DC 48 V on request ¹ When connecting with stranded wires, wire end ferrules must be used. Wiring diagram + M INT EXT 25.04.2018 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The compact high performance fan heater DCR 130 prevents formation of condensation and frost and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The fan heater is available with an integrated electronic thermostat or electronic hygrostat. The model with thermostat is available with internal or external sensor. The fan heater with integrated hygrostat is equipped with an external sensor. The external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and humidity. The DCR 130 was designed for wall fixing. For fixing on the bottom of the enclosure the fan heater DCR 030 is recommended. 4 www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com Part No. Model Operating voltage Heating capacity Recommended pre-fuse T (time-delay) Setting range3 temperature / humidity 13092.1-16 Thermostat with DC 24 V 200 W 25.0 A -4 to 104 °F DC 24 V 200 W 25.0 A -4 to 104 °F DC 56 V 800 W 25.0 A -4 to 104 °F DC 56 V 800 W 25.0 A -4 to 104 °F DC 24 V 200 W 25.0 A 40 to 90 % RH DC 56 V 600 W 25.0 A 40 to 90 % RH internal sensor 13092.1-17 Thermostat with connector for external sensor² 13097.3-16 Thermostat with internal sensor 13097.3-17 Thermostat with connector for external sensor² 13092.1-03 Hygrostat with connector for external sensor² 13095.3-03 Hygrostat with connector ² The external sensor needs to be ordered separately. ³ Switching difference temperature: 3 K (±1 K tolerance) at +77 °F (+25 °C), 50 % RH; Switching difference humidity: 4 % RH (±1 % tolerance) at +77 °F (+25 °C), 50 % RH. ACCESSORIES The external sensor is not included in the delivery of the DCR 130. It can be ordered separately. EXTERNAL SENSOR The external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and humidity. Part No. Length 267071 3.28 ft (1 m) 267072 6.56 ft (2 m) 267126 9.84 ft (3 m) 25.04.2018 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. for external sensor²
267071 价格&库存
很抱歉,暂时无法提供与“267071”相匹配的价格&库存,您可以联系我们找货
