01010.0-10
01010.0-10
    STEGO
    STEGO - 01010.0-10 - THERMOSTAT, NO, 13A, 56VDC - Operating Voltage:56VDC; Contact Current Max:13A; ...
01010.0-10 数据手册
8383 SWITCH MODULE DCM 010 | DC 20 to 56 V >>High DC switching capacity >>Variety of applications >>Wide DC voltage range >>Simple connection www.stego.de | www.stego.co.uk | www.stegonorden.se REGULATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET TECHNICAL DATA 44 93 53 1 Contact type contact maker normally open (MOSFET) Service life > 100,000 cycles Operating voltage DC 20 to 56 V Control contact – signal current 3 mA at DC 20 V / 4.5 mA at DC 24 V 14 mA at DC 48 V / 17 mA at DC 56 V Connection 6-pole terminal: stranded wire1 1.5 mm² (AWG 16); max. 2.5 mm² (AWG 12) Mounting clip for 35 mm DIN rail, EN 60715 Casing plastic according to UL94 V-0, grey (bicolor) Dimensions 93 x 53 x 44 mm Weight approx. 65 g Fitting position vertical Operating temperature see article table below Storage temperature -40 to +80 °C (-40 to +176 °F) Operating / Storage humidity max. 90 % RH (non-condensing) Protection type IP20 Approvals UL File No. E342261, VDE, EAC Note other versions on request When connecting with stranded wires, wire end ferrules must be used. Connection diagram Example of connection Heater Switch module DCM 010 Art. No. Max. switching capacity Operating temperature 01010.0-00 DC 15 A -30 to +40 °C (-22 to +104 °F) 01010.0-10 DC 13 A -30 to +50 °C (-22 to +122 °F) 01010.0-20 DC 11 A -30 to +60 °C (-22 to +140 °F) 30.11.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The switch module is used to control DC powered devices with high capacities in control and switch cabinets. It is controlled via an external potential-free contact (thermostat or hygrostat), which is connected between terminal 3 and 4. It must be ensured that the external contact is suitable to switch the required signal current without any problems.
01010.0-10 价格&库存
很抱歉,暂时无法提供与“01010.0-10”相匹配的价格&库存,您可以联系我们找货
