02527.0-10
    STEGO
02527.0-10 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com SLIMLINE LIGHT SL 025 >>Compact design >>Electronic ballast >>Optional integrated receptacle >>Screw or magnet mount >>Long-life energy saving lamp >>On/off switch Photo: Slimline light with on/off switch and integrated receptacle (Germany), Part No. 02520.0-00 TECHNICAL DATA Power consumption 11 W (~ 75 W incandescent bulb) Luminosity 900 Lm Lamp type compact fluorescent, 2G7 base, electronic ballast Service life 10,000 hrs. Switch (for light only) on/off switch Connection 3-pole terminal AWG 16 max. (2.5 mm²) with strain relief only (cable not included), clamping torque 0.8 Nm max. Housing plastic, UL 94V-0, light grey Mounting M5 screws (not included), 11.8” (300 mm) hole distance or optional attached magnet (see part nos. below) Operating / Storage temperature -4 to +122 °F (-20 to +50 °C) / -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions 13.6 x 3.6 x 1.6” (345 x 91 x 40 mm) Weight approx. 0.9 lbs. (400 g), 1.3 lbs (600 g) with magnet Protection type IP20 Note DC 24-48 V available upon request Part No. with On/Off Switch Model Operating Voltage Receptacle Rec. max. current Protection class 02520.0-00 without magnet AC 230 V, 50/60 Hz Germany/Russia 16 A I (grounded) VDE Approvals - GOST-R 02520.1-00 with magnet AC 230 V, 50/60 Hz Germany/Russia 16 A I (grounded) VDE - GOST-R 02521.0-00 without magnet AC 230 V, 50/60 Hz France/Poland 16 A I (grounded) VDE - GOST-R 02521.1-00 with magnet AC 230 V, 50/60 Hz France/Poland 16 A I (grounded) VDE - GOST-R 02522.0-00 without magnet AC 230 V, 50/60 Hz Switzerland 10 A I (grounded) VDE - GOST-R 02522.1-00 with magnet AC 230 V, 50/60 Hz Switzerland 10 A I (grounded) VDE - GOST-R 02523.0-00 without magnet AC 230 V, 50/60 Hz UK/Ireland 13 A I (grounded) VDE - GOST-R 02523.1-00 with magnet AC 230 V, 50/60 Hz UK/Ireland 13 A I (grounded) VDE - GOST-R 02524.0-01 without magnet AC 120 V, 50/60 Hz USA/Canada 15 A I (grounded) - UL File No. E234324 GOST-R 02524.1-01 with magnet AC 120 V, 50/60 Hz USA/Canada 15 A I (grounded) - UL File No. E234324 GOST-R 02527.0-00 without magnet AC 230 V, 50/60 Hz none - II (double insulated) VDE UL File No. E234324 GOST-R 02527.1-00 with magnet AC 230 V, 50/60 Hz none - II (double insulated) VDE UL File No. E234324 GOST-R 02527.0-10 without magnet AC 120 V, 50/60 Hz none - II (double insulated) - UL File No. E234324 GOST-R 02527.1-10 with magnet AC 120 V, 50/60 Hz none - II (double insulated) - UL File No. E234324 GOST-R 05.03.2015 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The SL 025 light was designed to fit in tight spaces in enclosures. It features an optional integrated receptacle so that electrical devices (e.g. power tools) can be easily plugged in when needed. The standard light can be screw mounted in a variety of positions, or the light can be fitted with an available magnet mount.
02527.0-10 价格&库存
很抱歉,暂时无法提供与“02527.0-10”相匹配的价格&库存,您可以联系我们找货
