03082.0-01
03082.0-01
    STEGO
03082.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com >>Compact size >>Flat design www.stegousa.com SPACE-SAVING FAN HEATER (fan included) HVI 030 | 500 - 700 W >>Built-in overheat protection >>Twist clip or screw mountable TECHNICAL DATA Heating element high performance cartridge Temperature safety cut-out with automatic reset and second-tier one shot fuse Axial fan, ball bearing service life 50,000 h at +77 °F (+25 °C) Air flow, free blowing 88 cfm (150 m³/h) Connection 2-pole dual pressure clamp for solid wire AWG 14 max. (2.5 mm²), stranded wire (with wire end ferrule) AWG 16 max. (1.5 mm²) Housing plastic, UL 94V-0, black Mounting twist clip for 35 mm DIN rail, EN 60715 or M6 screws and washers (not included), torque 2 Nm max. Mounting position vertical airflow (air outlet up) Operating temperature UL: +14 to +104 °F (-10 to +40 °C) VDE: +14 to +122 °F (-10 to +50 °C) Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions 6.65 x 5.0 x 3.5" (169 x 127 x 89 mm) Weight approx. 3.1 lbs (1.4 kg) Protection class / Protection type heater: II (double insulated), fan: I (grounded) / IP20 Approvals VDE, UL File No. E234324, GOST-R Note other heating capacities and voltages available on request View: back side Twist clip mount Screw mount Important note: Heater may only be operated together with fan (min. 88 cfm). Danger of overheating! Part No. - twist clip mounting Part No. - screw mounting Operating voltage Heating capacity 03082.0-00 03082.0-01 AC 230 V, 50/60 Hz 700 W Pre-fuse T (time-delay) 4A 03082.9-00 03082.9-01 AC 120 V, 50/60 Hz 700 W 8A 03083.0-00 03083.0-01 AC 230 V, 50/60 Hz 600 W 3.15 A 03083.9-00 03083.9-01 AC 120 V, 50/60 Hz 600 W 6.3 A 03084.0-00 03084.0-01 AC 230 V, 50/60 Hz 500 W 3.15 A 03084.9-00 03084.9-01 AC 120 V, 50/60 Hz 500 W 6.3 A 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The compact high-performance fan heater prevents formation of condensation and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The heater may only be operated together with a fan, but is also available without axial fan (for self-installation). The fan heaters are available with two different mounting systems – either mounting by screws or with a new and unique twist clip mounting system. These options allow for a quick and easy installation of the fan heater.
03082.0-01 价格&库存
很抱歉,暂时无法提供与“03082.0-01”相匹配的价格&库存,您可以联系我们找货
  • 1+1915.364341+248.50960
  • 5+1702.507375+220.89240
  • 1+1784.25486
  • 5+1585.97105
