08410.0-00
08410.0-00
    STEGO
08410.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com DRAINAGE DEVICE DD 084 | IP66 / IP67 / IP69K >>High degree of protection >>Good drainage performance >>Easy to install >>Weather and UV-light resistant Condensation can occur in enclosures with high protection types by variations in temperature. The use of a DD 084 drainage device allows the removal of the condensate without losing the maximum IP66 protection type. TECHNICAL DATA Mounting thread M50 x 1.5 with nut (wrench size 60 mm, housing 50 mm) Torque 6 Nm max. Depth in enclosure approx. 0.7" (17.5 mm) Material plastic according to UL 94V-0, umbra grey, weather and UV light resistant according UL 746C (f1) Water entry height 0 mm (at 0.5 mm wall thickness) Sealing sealing gasket NBR Water flow-through approx. 200 ml/hr at 5 mm water column Dimensions Ø 2.36" x 1.9" (Ø 60 x 49.5 mm) Mounting position vertical, lowest point Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Installation Make cut-out Ø 2.0 inches (50.5+0.5 mm) in enclosure bottom and mount drainage device with nut. Please make sure that the sealing gasket is put in place on the outer side panel of the enclosure and the hole is free of burrs. Mounting position Part No. Protection type Enclosure wall thickness 1 package unit Weight (approx.) 08410.0-00 IP66 / IP67 (EN 60529) / IP69K (EN 40050-9) 0.5 - 5.5 mm 1 piece 2 oz. (60 g) 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The specific characteristic of the water permeable membrane ensures the drainage of the condensate via capillary action. The unique construction also prohibits the ingression of splash water into the enclosure. Additionally, the drainage device effectively provides pressure compensation with variations in temperature.
08410.0-00 价格&库存
很抱歉,暂时无法提供与“08410.0-00”相匹配的价格&库存,您可以联系我们找货
    • 1+106.92928
    库存:150
