12124.0-00
    STEGO
    STEGO - 12124.0-00 - VARIOLINE LAMP W/SKT, DAYLIGHT WHT, 11W
12124.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com LED 121 On/off switch and screw fixing LED 122 Movement sensor and magnet fixing >>High luminous flux >>Integrated socket >>Durable and maintenance free LED technology www.stegousa.com VARIOLINE LAMP WITH SOCKET LED 121/122 >>Integrated power unit >>Daisy chain >>On/off switch, movement sensor or connection for external door switch TECHNICAL DATA 1.72in LED 121/122 magnet/screw fixing LED 121/122 side view Power consumption max. 11 W/16 W Operating voltage AC 220 - 240 V, 50/60 Hz (min. AC 200 V, max. AC 265 V) AC 120 V, 50/60 Hz (min. AC 110 V, max. AC 130 V) Luminous flux 1,080 Lm/1,730 Lm Lamp type LED, angle of radiation 120° light color: daylight, color temperature: 6,500 K Service life 60,000 h at +20 °C (+68 °F) Connection 3-pole connector with snap lock AC: max. 16 A / AC 240 V, color: white Mounting magnet fixing or screw fixing (M5), torque 2 Nm max. Casing plastic, translucent Dimensions see drawings Weight approx. 0.3 kg/0.4 kg Operating/Storage temperature -30 to +40 °C (-22 to +104 °F) / -40 to +85 °C (-40 to +185 °F) Operation/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP20 / I (earthed) L1 L2 Mounting options: The lamps are available with magnet fixing for easy positioning in any steel cabinet or enclosure. A classic is the LED 121/122 with screw fixing. With a total rotation angle of 120° it provides perfect illumination. Note: The lamp must not be used for household lighting. 5.85in View of magnet fixing 3.9in LED 121 (Size 1) L1 = 15.6 in L2 = 14.6 in LED 122 (Size 2) L1 = 27.3 in L2 = 26.3 in View of screw fixing 15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The LED 121/122 Varioline is a powerful and compact LED lamp with integrated socket for use in enclosures. Featuring socket standards of many European countries as well as the US and Australia, it allows for the power connection of laptops and diagnostic devices. Its LED tube emits more than 1,000/1,700 Lm thereby illuminating even very large enclosures in their full depth and height. The glare-free, 120° rotatable light tube uses Mid-power LEDs with a service life of 60,000 h. www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com VARIOLINE LED 121/122 ON/OFF SWITCH Size 1: L1 = 500 mm Size 2: L1 = 700 mm Art. No. Magnet fixing Art. No. Screw fixing Art. No. Magnet fixing Art. No. Screw fixing Operating voltage Socket Nominal current of socket Approvals 12100.0-30 12100.0-00 12200.0-30 12200.0-00 AC 220 – 240 V, 50/60 Hz Germany/Russia (1) 16.0 A VDE – 12101.0-30 12101.0-00 12201.0-30 12201.0-00 AC 220 – 240 V, 50/60 Hz FR/PL/CZ/SK (2) 16.0 A VDE – 12102.0-30 12102.0-00 12202.0-30 12202.0-00 AC 220 – 240 V, 50/60 Hz Switzerland (3) 10.0 A – – 12103.0-30 12103.0-00 12203.0-30 12203.0-00 AC 220 – 240 V, 50/60 Hz UK/Ireland (4) 13.0 A VDE – 12104.0-30 12104.0-00 12204.0-30 12204.0-00 AC 120 V, 50/60 Hz USA/Canada (5) 15.0 A – UL 12105.0-30 12105.0-00 12205.0-30 12205.0-00 AC 220 – 240 V, 50/60 Hz Italy (6) 16.0 A VDE – 12107.0-30 12107.0-00 12207.0-30 12207.0-00 AC 220 – 240 V, 50/60 Hz Australia (7) 10.0 A VDE – VARIOLINE LED 121/122 PIR MOVEMENT SENSOR 1 Size 2: L1 = 700 mm Art. No. Screw fixing Art. No. Magnet fixing Art. No. Screw fixing Operating voltage Socket Nominal current of socket Approvals 12110.0-30 12110.0-00 12210.0-30 12210.0-00 AC 220 – 240 V, 50/60 Hz Germany/Russia (1) 16.0 A VDE – 12111.0-30 12111.0-00 12211.0-30 12211.0-00 AC 220 – 240 V, 50/60 Hz FR/PL/CZ/SK (2) 16.0 A VDE – 12112.0-30 12112.0-00 12212.0-30 12212.0-00 AC 220 – 240 V, 50/60 Hz Switzerland (3) 10.0 A – – 12113.0-30 12113.0-00 12213.0-30 12213.0-00 AC 220 – 240 V, 50/60 Hz UK/Ireland (4) 13.0 A VDE – 12114.0-30 12114.0-00 12214.0-30 12214.0-00 AC 120 V, 50/60 Hz USA/Canada (5) 15.0 A – UL 12115.0-30 12115.0-00 12215.0-30 12215.0-00 AC 220 – 240 V, 50/60 Hz Italy (6) 16.0 A VDE – 12117.0-30 12117.0-00 12217.0-30 12217.0-00 AC 220 – 240 V, 50/60 Hz Australia (7) 10.0 A VDE – ¹ approx. 5 min fixed switch-on duration VARIOLINE LED 121/122 WITH CONNECTION FOR EXTERNAL DOOR SWITCH Size 1: L1 = 500 mm Size 2: L1 = 700 mm Art. No. Magnet fixing Art. No. Screw fixing Art. No. Magnet fixing Art. No. Screw fixing Operating voltage Socket Nominal current of socket Approvals 12120.0-30 12120.0-00 12220.0-30 12220.0-00 AC 220 – 240 V, 50/60 Hz Germany/Russia (1) 16.0 A VDE – 12121.0-30 12121.0-00 12221.0-30 12221.0-00 AC 220 – 240 V, 50/60 Hz FR/PL/CZ/SK (2) 16.0 A VDE – 12122.0-30 12122.0-00 12222.0-30 12222.0-00 AC 220 – 240 V, 50/60 Hz Switzerland (3) 10.0 A – – 12123.0-30 12123.0-00 12223.0-30 12223.0-00 AC 220 – 240 V, 50/60 Hz UK/Ireland (4) 13.0 A VDE – 12124.0-30 12124.0-00 12224.0-30 12224.0-00 AC 120 V, 50/60 Hz USA/Canada (5) 15.0 A – UL 12125.0-30 12125.0-00 12225.0-30 12225.0-00 AC 220 – 240 V, 50/60 Hz Italy (6) 16.0 A VDE – 12127.0-30 12127.0-00 12227.0-30 12227.0-00 AC 220 – 240 V, 50/60 Hz Australia (7) 10.0 A VDE – VARIOLINE LED 121/122 WITHOUT SWITCHING OPTION Size 1: L1 = 500 mm Size 2: L1 = 700 mm Art. No. Magnet fixing Art. No. Screw fixing Art. No. Magnet fixing Art. No. Screw fixing Operating voltage Socket Nominal current of socket 12130.0-30 12130.0-00 12230.0-30 12230.0-00 AC 220 – 240 V, 50/60 Hz Germany/Russia (1) 16.0 A VDE – 12131.0-30 12131.0-00 12231.0-30 12231.0-00 AC 220 – 240 V, 50/60 Hz FR/PL/CZ/SK (2) 16.0 A VDE – 12132.0-30 12132.0-00 12232.0-30 12232.0-00 AC 220 – 240 V, 50/60 Hz Switzerland (3) 10.0 A – – 12133.0-30 12133.0-00 12233.0-30 12233.0-00 AC 220 – 240 V, 50/60 Hz UK/Ireland (4) 13.0 A VDE – 12134.0-30 12134.0-00 12234.0-30 12234.0-00 AC 120 V, 50/60 Hz USA/Canada (5) 15.0 A – UL 12135.0-30 12135.0-00 12235.0-30 12235.0-00 AC 220 – 240 V, 50/60 Hz Italy (6) 16.0 A VDE – 12137.0-30 12137.0-00 12237.0-30 12237.0-00 AC 220 – 240 V, 50/60 Hz Australia (7) 10.0 A VDE – (1) (2) (3) (4) (5) (6) (7) Approvals 15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Size 1: L1 = 500 mm Art. No. Magnet fixing Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com ACCESSORIES LED 121/122 Connetors and cables for electrical connection are not included in the delivery of the LED 121/122. These parts can be ordered separately. Sets, consisting of lamp and accessories, are available on request. Likewise, custom cables are available on request. LAMP-SET WITH FEMALE CONNECTOR Varioline LED enclosure lamps are also available as a set including the connector Art. No. 264093. Simply add -0003 to the article number of the required lamp. For example: 12100.0-30-0003. Sets for lamps with external door switch contain in addition the male connector 264090. FEMALE / MALE CONNECTORS Photo: Female connector, Art. No. 264093 Art. No. Model Voltage type Color Use for Wire cross-section1 Approvals 264093 female connector AC white power input and daisy chain 0,75-2,5 mm2 (AWG 14-18) VDE + UL 264091 female connector AC white power input 0,75-2,5 mm2 (AWG 14-18) VDE + UL 264090 male connector AC grey door switch 0,5-2,5 mm2 (AWG 14-20) VDE + UL applies to rigid and stranded wire. Wire end ferrules must be used when connecting with stranded wires CONNECTION CABLE WITH FEMALE CONNECTOR AND OPEN END Photo: Connection cable, Art. No. 244422 1 Art. No. Model Length Color Use for 244422 connection cable 3 x 1.5 mm² with female connector 4.0 m connector: white; cable: white power input Approvals² VDE 244423 connection cable 3 x AWG 16 with female connector 4.0 m connector: white; cable: white power input VDE + UL Approvals² ² applies only to the individual components (cable and connectors) EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN CONNECTION Photo: Extension cable, Art. No. 244358 2 Art. No. Model Length Color Use for 244358 extension cable 2 x 1.5 mm² with 2 connectors 1.0 m connectors: white; cable: white daisy chain VDE 244359 extension cable 2 x AWG 16 with 2 connectors 1.0 m connectors: white; cable: white daisy chain VDE + UL Approvals² ² applies only to the individual components (cable and connectors) CONNECTION CABLE WITH MALE CONNECTOR AND OPEN END Photo: Connection cable, Art. No. 244424 3 Art. No. Model Length Color Use for 244424 connection cable 2 x 1.5 mm² with male connector 0.6 m male connector: grey; cable: white power output VDE 244425 connection cable 2 x AWG 16 with male connector 0.6 m male connector: grey; cable: white power output VDE + UL ² applies only to the individual components (cable and connectors) CONNECTION EXAMPLE 2 0.75in 1 2in 1.56in 0.75in 3 The lamps are conveniently connected via connection plugs - up to 8 lamps max. can be daisy-chained this way. Female/male connectors are also available to assemble cables in non-standard lengths. 15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. 1 Photo: Male connector, Art. No. 264090 Photo: Female connector, Art. No. 264091
12124.0-00
物料型号: - LED 121/122
器件简介: - 高光通量 - 集成插座 - 耐用且免维护的LED技术
引脚分配: - 3极连接器带自锁,AC最大16A/AC 240V,颜色为白色
参数特性: - 功率消耗:最大11W/16W - 工作电压:AC 220-240V, 50/60 Hz(最小AC 200V,最大AC265V); AC120V, 50/60Hz(最小AC110V,最大AC130V) - 光通量:1080Lm/1730Lm - 灯类型:LED,辐射角度120°,光色:日光色,色温:6500K - 服务寿命:60,000小时在+20°C(+68°F) - 安装:磁铁固定或螺丝固定(M5),最大扭矩2Nm - 外壳:塑料,半透明 - 尺寸:详见图纸 - 重量:约0.3 kg/0.4kg - 操作/存储温度:-30至+40°C(-22至+104°F)/-40至+85°C(-40至+185°F) - 操作/存储湿度:最大90% RH(不凝结) - 保护类型/保护等级:IP20/I(接地)
功能详解: - 集成电源单元 - 串联连接 - 开关、运动传感器或连接外部门开关
应用信息: - 用于机柜的LED灯,具有多种欧洲国家以及美国和澳大利亚的插座标准,适用于笔记本电脑和诊断设备的电源连接。
封装信息: - 提供磁铁固定和螺丝固定两种安装选项,具有120°的总旋转角度,提供完美的照明。
12124.0-00 价格&库存
很抱歉,暂时无法提供与“12124.0-00”相匹配的价格&库存,您可以联系我们找货
