101101
PRESSURE COMPENSATION DEVICE (STAINLESS STEEL)
DA 284 | IP66
>>High degree of protection
>>Waterproof membrane
>>Corrosion resistant
>>Food safe
Pressure differentials in enclosures with a high degree of protection are a result of internal and external temperature
changes. In the case of negative pressure or partical vacuum, dust and humidity can enter the enclosure through
the door seal. When the air inside the enclosure cools down, condensation may occur because the humidity
cannot escape the enclosure. The easy-to-install pressure compensation device DA 284 provides compensation of
pressure at a protection degree of IP66. Even with a slight overpressure, a waterproof membrane inside the plug
allows the humidity to escape whilst blocking water and dirt from entering the enclosure.
Photo: Inside view
TECHNICAL DATA
Mounting
thread M40 x 1.5 with nut
Torque
5 Nm
Depth in enclosure
approx. 9 mm
Sealing
sealing gasket NBR
Filter
waterproof membrane
Air permeability
1,200 l/h at a pressure difference of min. 70mbar
Dimensions
Ø 58 x 31 mm
Fitting position
variable
Operating/Storage temperature
-45 to +80 °C (-49 to +176 °F)
Approvals
EAC
Installation: Make cut-out Ø 40.5+0,5 mm in enclosure wall and mount pressure compensation device with nut. Please make
sure that the sealing gasket is put in place on the outer side panel of the enclosure. For optimal pressure compensation we
recommend to use two devices on opposite sides towards the top of the enclosure.
1
Art. No.
Stainless steel
Protection type
1 packaging unit
Weight (approx.)
28401.0-00
V2A (DIN 1.4301 / AISI 304)1
IP66 (EN 60529) / IPX9K (EN 40050-9)
1 piece
0.2 kg
28401.0-02
V4A (DIN 1.4404 / AISI 316L)
1 piece
0.2 kg
V2A is not sea waterproof
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
www.stego.de | www.stego.co.uk | www.stegonorden.se
ACCESSORIES
STEGO - PRODUCT
CATALOGUE
TECHNICAL
DATASHEET
很抱歉,暂时无法提供与“28401.0-00”相匹配的价格&库存,您可以联系我们找货
