01624.0-03
01624.0-03
    STEGO
01624.0-03 数据手册
14 HEATING PRODUCT CATALOG - STEGO, Inc. Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com PTC HEATER RCE 016 | 5 W, 9 W > Compact size > Wide voltage range > Energy saving > Heating power adjusts to ambient temperature TECHNICAL DATA Operating voltage see table below Heating element PTC resistor, temperature limiting Heater body aluminum, anodized Insulation PTFE / Kapton Mounting 2 pressure clips included (mounting screws not included) Mounting position variable Dimensions length 1.77", Ø 0.39" (45 mm, Ø 10 mm) Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 % RH (non-condensing) Protection class / Protection type II (double insulated) / IP54 PTC Heater RCE 016 Wiring example RCE 016 Heater Thermostat Mounting clip Part No. Heating capacity¹ Operating voltage² Max. current (inrush) Recommended pre-fuse T (time-delay) Surface temperature (approx.)1 Weight (approx.) 01622.0-03 5W AC/DC 120 – 240 V 01623.0-01 9W AC/DC 120 – 240 V 01624.0-03 5W 01625.0-02 9W Approvals 2.0 A 2.0 A 329 °F (165 °C) 0.7 oz. (20 g) UL File No. E234324 VDE EAC 2.5 A 4.0 A 347 °F (175 °C) 0.7 oz. (20 g) UL File No. E234324 VDE EAC AC/DC 12 – 30 V 5.8 A 6.3 A 284 °F (140 °C) 0.7 oz. (20 g) UL File No. E234324 EAC AC/DC 12 – 30 V 2.4 A 4.0 A 360 °F (182 °C) 0.7 oz. (20 g) UL File No. E234324 EAC ¹ at 68 °F (20 °C) ambient temperature; ² operating high voltage heaters below AC/DC 140 V reduces heating performance by approx. 10% (min. 110 V, max 265 V) 18.02.2020 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The RCE 016 small heaters have been designed to prevent condensation and to ensure a minimum operating temperature in small enclosures. They are suitable for permanent operation.
01624.0-03 价格&库存
很抱歉,暂时无法提供与“01624.0-03”相匹配的价格&库存,您可以联系我们找货
