01804.0-00
01804.0-00
    STEGO
01804.0-00 数据手册
38TECHNICAL 38 COOLING DATASHEET www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO FILTER FAN FF 018 | 200m³/h >>Low maintenance >>High through-flow air volume >>Functional design >>Time-saving installation >>UV resistant Filter Fan TECHNICAL DATA View from rear Exit filter Drilling template for mounting frame Axial fan, ball bearing service life 50,000h at +25°C (+77°F), 65% RH fan body aluminium, rotor metal Connection 3-pole clamp for 2.5mm², clamping torque 0.8Nm max. Casing (filter fan and exit filter) plastic according to UL94 V-0, light grey Hood (filter fan and exit filter) plastic according to UL94 V-0, light grey; UV light resistant according to UL746C (f1) Mounting frame with double-sided industrial adhesive band for fixing to the outside of enclosure; certain operating circumstances can make the additional use of screws necessary (see drilling template); a template for the enclosure cut-out is included in the delivery of the filter fans Filter mat G4 acc. to DIN EN 779, filtering degree 94% Filter material synthetic fibre with progressive construction, temperature resistant to +100°C, self-extinguishing class F1, moisture resistant to 100% RH, reusable - cleaning by washing or vacuuming Operating/Storage temperature 230VAC: -25 to +50°C (-13 to +122°F) 120VAC: -25 to +60°C (-13 to +140°F) Operating/Storage humidity max. 90% RH (non-condensing) Protection class I (earthed) Approvals UL File No. E234324, EAC, VDE only: 230V FILTER FAN FF 018 Art. No. Operating voltage Air volume, free flow Air volume with exit filter Current consumption Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Enclosure cut-out Weight (approx.) Protection type 01804.0-00 230VAC, 50Hz 200m³/h 125m³/h 320mA 45W 52dB (A) 95mm 176 x 176mm + 0.4 1.7kg IP54/IP551 01804.0-01 120VAC, 60Hz 230m³/h 143m³/h 470mA 39W 52dB (A) 95mm 176 x 176mm + 0.4 1.7kg IP54/IP551 EXIT FILTER EF 118 Art. No. Depth in enclosure Enclosure cut-out Weight (approx.) Filter mat Protection type 11802.0-00 16mm 176 x 176mm + 0.4 0.6kg G4 acc. to DIN EN 779, filtering degree 94% IP54/IP551 FILTER MAT FM 086/FFM 086 1 Filter mat 168 x 168mm G4 (1 packing unit = 3 pcs.) Art. No. 08602.0-00 F5/M5 (1 packaging unit = 3 pcs.) Art. No. 08605.0-00 Using fine filter mats type F5/M5 increases the protection type to IP55, but reduces the air volume 20.03.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Filter fans are used to provide an optimum climate in enclosures. The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting air flow prevents formation of localised hot pockets and protects the electronic components from overheating. These filter fans are intended for indoor use. The plastic used for the hood is highly UV light resistant.
01804.0-00 价格&库存
很抱歉,暂时无法提供与“01804.0-00”相匹配的价格&库存,您可以联系我们找货
  • 1+1416.94548
  • 3+1357.90948
  • 10+1273.59564
库存:5
01804.0-00
  • 1+1405.019921+181.37630
  • 3+1346.546733+173.82790
  • 10+1262.8635310+163.02510
库存:5
