01880.1-00
01880.1-00
    STEGO
    STEGO - 01880.1-00 - OUT FILTER FAN, 48VDC, 3W, 3.62 X 3.62"
01880.1-00 数据手册
56TECHNICAL 56 COOLING DATASHEET FILTER FAN PLUS – DC LINE FPI/FPO 018 | up to 33 m³/h (92 x 92 mm) > New air-flap outlet technology for high airflow > Easy mounting > Protection type test/Environmental rating by independent testing institutes (VDE and UL) > Two systems for optimal airflow (FPI/FPO) > Standard enclosure cut-out sizes > One filter mat Filter fans are used to provide an optimum climate in enclosures and cabinets with electrical/electronic components. The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting airflow prevents formation of localised hot pockets in installations and protects electronic components from overheating. The Filter Fan Plus series uses a new air-flap outlet technology for the air outlet and thus reaches a high degree of airflow. A ratchet mechanism is used for mounting and provides high stability and tightness. Depending on the application there are two systems that are available – the FPI or FPO system. The FPI system is a standard installation with a filter fan in the lower part of the enclosure which ensures that fresh air is fed into the enclosure (airflow direction "In"). This system consists of a filter fan and exit filter. Whereas in the FPO system, the filter fan is located in the upper area of the enclosure to avoid heat buildups (airflow direction "Out"). The FPO system is composed of an intake filter and exit filter fan. The Filter Fan Plus series has been designed for indoor use. TECHNICAL DATA warm SYSTEM FPI Exit Filter FPI 118 Air-flaps Filter Fan FPI 018 Axial fan, ball bearing service life L10 at +40 °C (+104 °F): min. 70,000 h plastic Connection 2 stranded wires, 300 mm Casing, hood, flaps plastic according to UL94 V-0, light grey; UV light resistant according to UL746C (f1) Enclosure cut-out 92 x 92+1 mm Mounting frame 4 built-in ratchet braces for mounting (6 notches for wall thickness 1 – 4 mm). Additional use of screws possible if needed1. Filter mat G3 acc. to DIN EN 779, average arrestance Aa 84 % Filter material synthetic fibre with progressive construction, temperature resistant to +100 °C, self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating temperature -20 to +70 °C (-4 to +158 °F) Storage temperature -40 to +70 °C (-40 to +158 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP54 / II (double insulated) Environmental rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals VDE, UL File No. E234324, EAC Note other voltages on request cold Filter mat 1 Drilling marks for screw mounting are indicated on mounting frame. AIRFLOW DIRECTION "IN": FILTER FAN FPI 018 Art. No. Operating voltage Air volume, free flow Air volume with exit filter Current consumption Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) Filter mat 01870.2-30 DC 24 V 22 m³/h 16 m³/h 113 mA 2.7 W 49 dB (A) 59 mm 0.3 kg G3 01870.1-30 DC 48 V 23 m³/h 17 m³/h 63 mA 3.0 W 51 dB (A) 59 mm 0.3 kg G3 AIRFLOW DIRECTION "IN": EXIT FILTER FPI 118 Art. No. Depth in enclosure Weight (approx.) Air outlet 11870.0-00 29 mm 0.2 kg air-flap outlet technology 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO 57 57 COOLING www.stego.de | www.stego.co.uk | www.stegonorden.se STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET warm SYSTEM FPO Filter Fan FPO 018 Air-flaps Intake Filter FPO 118 AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018 Art. No. Operating voltage Air volume, free flow Air volume with intake filter Current consumption Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) Air outlet 01880.2-00 DC 24 V 31 m³/h 17 m³/h 113 mA 2.7 W 48 dB (A) 66 mm 0.3 kg air-flaps 01880.1-00 DC 48 V 33 m³/h 18 m³/h 63 mA 3.0 W 49 dB (A) 66 mm 0.3 kg air-flaps AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118 Art. No. Depth in enclosure Weight (approx.) Filter mat 11880.0-30 22 mm 0.2 kg G3 acc. to DIN EN 779, average arrestance Aa 84 % FILTER MAT FM 086 Filter class 84 x 84 mm Average arrestance Aa 1 packing unit G3 acc. to DIN EN 779 Art. No. 08633.0-00 84 % 5 pieces TECHNICAL DRAWINGS FPI 018 22 120 120 66 72 92 92 29 FPI 118 22 2222 22 92 2222 92 59 66 92 92 120 120 FPO 018 FPO 118 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. cold Filter mat
01880.1-00
物料型号: - FPI 018 和 FPO 018 是两种型号的过滤风扇。
器件简介: - 过滤风扇用于将冷却的过滤空气引入外壳内,驱逐内部热空气,防止局部热点的形成,保护电子组件免受过热。
引脚分配: - 连接:两股电线,长度300毫米。
参数特性: - 外壳、罩和空气瓣材料:UL94 V-0标准的塑料,浅灰色,抗紫外线。 - 过滤器:G3等级,合成纤维,可重复使用,耐高温达+100°C,自熄等级F1,抗100%湿度。 - 工作温度:-20至+70°C。 - 存储温度:-40至+70°C。 - 工作/存储湿度:最大90%RH(不凝结)。 - 防护等级:IP54/I(双重绝缘)。 - 环境等级:UL TYPE12/NEMA12。 - 认证:VDE, UL。
功能详解: - 过滤风扇采用新的出风口空气瓣技术,通过棘轮机构安装,提供高稳定性和密封性。 - FPI系统:过滤风扇位于外壳下部,确保新鲜空气进入。 - FPO系统:过滤风扇位于外壳上部,以避免热量积聚。
应用信息: - 适用于室内使用。
封装信息: - 外壳切割尺寸:92x92mm。 - 安装框架:4个内置棘轮支架,适用于1-4mm壁厚,必要时可使用螺丝。
01880.1-00 价格&库存
很抱歉,暂时无法提供与“01880.1-00”相匹配的价格&库存,您可以联系我们找货
