01884.0-01
01884.0-01
    STEGO
    STEGO - 01884.0-01 - FILTER FAN, SYNTHETIC MESH, 594.5CFM
01884.0-01 数据手册
COOLING PRODUCT CATALOG - STEGO, Inc. > New air-flap outlet technology for high airflow > Easy mounting > Protection type/Environmental ratings by independent testing agencies (VDE & UL) www.stegousa.com FILTER FAN PLUS FPI/FPO 018 | up to 606.8 cfm (11.5 x 11.5") > Two optional systems for optimal airflow (FPI/FPO) > Industry-common enclosure cut-out sizes (5 sizes) > Single filter mat system design > Two fan speeds Filter fans are used to provide "cooling" by forced air-circulation in enclosures and cabinets containing eletrical/ electronic and other components. The interior temperature of an enclosure can be reduced by channelling cooler, filtered outside air into the enclosure, thus expelling hot inside air. The resulting airflow prevents formation of localized hot pockets and protects electronic components from overheating. The Filter Fan Plus series encompasses a new air-flap technology on the air outlet side, thereby reaching an unparalleled high degree of airflow. A unique ratchet mechanism is used for easy installation. It provides safe and secure mounting while guaranteeing a tight seal. Depending on the requirements, there are two optional systems available – the FPI or the FPO system (FPI = "in", FPO = "out"). The FPI system is the more commonly known installation system, where a filter fan located in the lower part of the enclosure draws cleaner, cooler air into the enclosure (airflow direction "In"). This system consists of a filter fan and exhaust filter. On opposite, with the newer FPO system, the filter fan will be located in the upper area of the enclosure to draw warmer air out of the enclosure (airflow direction "Out"). The FPO system consists of an intake filter and exhaust filter fan. The Filter Fan Plus series may also be used outdoors with appropriate protective measures or when equipped with weather proof accessories, e.g. Hose-proof Hood FFH 086. TECHNICAL DATA 11.5" (291 mm) ENCLOSURE CUT-OUT 1 Axial fan, ball bearing fan speed 1: service life L10 at +104 °F (+40 °C): min. 76,000 h metal impeller fan speed 2: service life L10 at +104 °F (+40 °C): min. 54,000 h plastic impeller Connection 3-pole clamp for AWG 14 (2.5 mm²), clamping torque 0.8 Nm max. Housing, hood, flaps plastic UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Enclosure cut-out 11.5 x 11.5+0.04 inches (291 x 291+1 mm) Mounting frame 4 built-in ratchet push levers for mounting (6 ratchet stops to accommodate for wall thicknesses Gauge 9 to 19 or 1 – 4 mm). Additional screw mounting possible if needed1. Filter mat ISO coarse 55% acc. to ISO 16890 (G3), init. grav. arrestance 57% Filter material synthetic mesh with progressive construction, temperature resistant to +212 °F (+100 °C), self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating temperature fan speed 1 & 2, 50 Hz: -13 to +131 °F (-25 to +55 °C) fan speed 1, 60 Hz: -13 to +95 °F (-25 to +35 °C) fan speed 2, 60 Hz: -13 to +122 °F (-25 to +50 °C) Storage temperature -40 to +158 °F (-40 to +70 °C) Operating/Storage humidity max. 75 % RH (non-condensing) Protection type/Protection class IP54 / I (grounded) Environmental rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals UL File No. E234324, VDE, EAC Note other voltages on request Drilling hole markings for screw mounting are indicated on mounting frame. 28.07.2020 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. 54 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com 55 www.stegousa.com COOLING PRODUCT CATALOG - STEGO, Inc. Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com warm SYSTEM FPI 1.14"1.14" (29mm) (29mm) 6.30" 6.30" (160mm) (160mm) 12.68" 12.68" (322mm) (322mm) Exhaust Filter FPI 118 1.97"1.97"1.14"1.14" (50mm) (50mm) (29mm) (29mm) 11.46" (291mm) 11.46" (291mm) 11.46" (291mm) 11.46" (291mm) Air-flaps Filter Fan FPI 018 FPI 018 cold Filter mat FPI 118 Part No. Operating voltage Fan speed Air volume, free blowing Air volume with exhaust filter Current consumption Power (50/60 Hz) consumption 01874.0-30 AC 230 V, 50/60 Hz 1 254.8 cfm (433 m³/h) 219.5 cfm (373 m³/h) 400/480 mA 01874.0-31 AC 230 V, 50/60 Hz 2 367.3 cfm (624 m³/h) 329.6 cfm (560 m³/h) 550/700 mA 01874.9-30 AC 115 V, 50/60 Hz 1 231.9 cfm (394 m³/h) 199.5 cfm (339 m³/h) 660/800 mA 01874.9-31 AC 115 V, 50/60 Hz 2 391.4 cfm (665 m³/h) 349 cfm (593 m³/h) 1100/1450 mA Average noise level (DIN EN ISO 4871) Mounting depth Weight (approx.) Filter mat 95 W 62 dB (A) 6.3" (160 mm) 6.8 lbs. (3.1 kg) G3 140 W 70 dB (A) 6.3" (160 mm) 7.3 lbs. (3.3 kg) G3 90 W 61 dB (A) 6.3" (160 mm) 6.8 lbs. (3.1 kg) G3 165 W 72 dB (A) 6.3" (160 mm) 7.3 lbs. (3.3 kg) G3 AIRFLOW DIRECTION "IN": EXHAUST FILTER FPI 118 Part No. Mounting depth Weight (approx.) Air outlet 11874.0-00 2.0" (50 mm) 2.2 lbs. (1.0 kg) air-flap outlet technology warm SYSTEM FPO 0.98" 0.98" (25mm) (25mm) 1.14"1.14" 1.14"1.14" 6.30" 6.30" (160mm) (160mm)(29mm) (29mm) (29mm) (29mm) 12.68" 12.68" (322mm) (322mm) Filter Fan FPO 018 11.46" (291mm) 11.46" (291mm) 11.46" (291mm) 11.46" (291mm) Air-flaps Intake Filter FPO 118 FPO 018 cold Filter mat FPO 118 AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018 Part No. Operating voltage 01884.0-00 AC 230 V, 50/60 Hz 01884.0-01 AC 230 V, 50/60 Hz 01884.9-00 AC 115 V, 50/60 Hz 01884.9-01 AC 115 V, 50/60 Hz Fan speed Air volume, free blowing Air volume with intake filter Current consumption Power Average noise level (50/60 Hz) consumption (DIN EN ISO 4871) 1 427.9 cfm (727 m³/h) 243.1 cfm (413 m³/h) 400/480 mA 95 W 2 594.5 cfm (1010 m³/h) 352.6 cfm (599 m³/h) 550/700 mA 140 W 1 413.8 cfm (703 m³/h) 230.1 cfm (391 m³/h) 660/800 mA 90 W 2 606.8 cfm (1031 m³/h) 358.4 cfm (609 m³/h 1100/1450 mA 165 W Mounting depth Weight (approx.) Air outlet 63 dB (A) 6.3" (160 mm) 7.0 lbs. (3.2 kg) air-flaps 70 dB (A) 6.3" (160 mm) 7.0 lbs. (3.2 kg) air-flaps 62 dB (A) 6.3" (160 mm) 7.0 lbs. (3.2 kg) air-flaps 71 dB (A) 6.3" (160 mm) 7.0 lbs. (3.2 kg) air-flaps AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118 Part No. Mounting depth Weight (approx.) Filter mat 11884.0-30 1.0" (25 mm) 1.8 lbs. (0.8 kg) ISO coarse 55 % acc. to ISO 16890 (G3), initial gravimetric arrestance 57 % FILTER MAT FM 086 Filter class 11.14 x 11.14" (283 x 283 mm) Initial gravimetric arrestance 1 packing unit ISO coarse 55% acc. to ISO 16890 (G3) Part No. 08637.0-00 57 % 5 pieces 28.07.2020 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. AIRFLOW DIRECTION "IN": FILTER FAN FPI 018
01884.0-01 价格&库存
很抱歉,暂时无法提供与“01884.0-01”相匹配的价格&库存,您可以联系我们找货
  • 1+3609.26930
  • 5+3248.33613
库存:1
