02542.3-11
02542.3-11
    STEGO
    STEGO - 02542.3-11 - ENCLOSURE LIGHT, 5W, 240V, SCREW MNT
02542.3-11 数据手册
2 LIGHTING PRODUCT CATALOG - STEGO, Inc. Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com ECOLINE LIGHT LED 025 >>Energy saving LED technology >>Wide voltage range >>Integrated power unit LED 025 Light with clip mount >>Magnet, screw or clip mount >>Wide variety of connections >>Dual cage clamp for quick wiring LED 025 Light with motion sensor and screw mount On/off switch light w/magnet or screw mount TECHNICAL DATA LED 025 Light with on/off switch and magnet mount On/off switch light w/clip mount Ecoline Light LED 025 top view Power consumption max. 5 W (~ 75 W incandescent bulb) Luminosity 400 Lm at 120° (1,200 Lm at 360° or equivalent 95 W light bulb) Lamp type LED, 120° angle of radiation light color – daylight, color temperature – 6,000 to 7,000 K Service life 60,000 hrs. at 68°F (20°C) Connection 2-pole dual cage clamp for solid wire AWG 14 (2.5 mm2), and stranded wire (wire end ferrule) AWG 16 (1.5 mm2) Housing plastic, transparent Mounting magnet, M5 screws (not included), or clip (M6 screws), torque 2 Nm max. Operating / Storage temperature -22 to +140 °F (-30 to +60 °C ) / -40 to +185 °F (-40 to +85 °C) Operating / Storage humidity max. 90 % RH (non-condensing) Dimensions see drawings Weight approx. 7 oz. (200 g) Protection type / Protection class IP20 / II (double insulated) Mounting options: The lights are available with magnet mount for easy positioning in any steel cabinet or enclosure. Other options are the LED 025 with screw mount, and specifically designed clip holders for clip mount of the LED 025. These can be positioned anywhere in the cabinet by simply screwing the holders to the cabinet wall. The light is snapped into the clip holders and can be turned in both directions. With a total rotation angle of 180° it provides perfect illumination within the cabinet or enclosure. Magnet mount end view Part No. – magnet mount Part No. – screw mount Part No. – clip mount 02540.3-10 02540.3-11 02541.3-10 Screw mount end view Clip mount end view Operating voltage Switch type Approvals 02540.3-13 AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 90 – 110 V (min. DC 80 V, max. DC 125 V) on/off switch UL File No. E234324 VDE (REG.-Nr. E788)1 EAC 02541.3-11 02541.3-13 AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 90 – 110 V (min. DC 80 V, max. DC 125 V) PIR motion sensor2 UL File No. E234324 VDE (REG.-Nr. E788)1 EAC 02542.3-10 02542.3-11 02542.3-13 AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 90 – 110 V (min. DC 80 V, max. DC 125 V) N/A UL File No. E234324 VDE (REG.-Nr. E788)1 EAC 02540.1-10 02540.1-11 02540.1-13 DC 24 – 48 V (min. DC 20 V, max. DC 60 V) on/off light switch UL File No. E234324 VDE (REG.-Nr. E788)1 EAC 02541.1-10 02541.1-11 02541.1-13 DC 24 – 48 V (min. DC 20 V, max. DC 60 V) PIR motion sensor2 UL File No. E234324 VDE (REG.-Nr. E788)1 EAC 02542.1-10 02542.1-11 02542.1-13 DC 24 – 48 V (min. DC 20 V, max. DC 60 V) N/A UL File No. E234324 VDE (REG.-Nr. E788)1 EAC VDE Certificate of Conformity (REG.-Nr. E788); Passive Infrared (PIR) motion sensor is factory pre-set to turn the light off 5 minutes after all motion ceases Note: The lights are not approved for household lighting. 1 2 01.08.2017 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The LED 025 light series is suitable for all types of panels and enclosures, especially where space is at a premium. These lights have a very long service life due to the use of LED technology. They are available with powerful non-slip rubberized magnets allowing them to be easily positioned in any steel enclosure. Screw and clip mounting are also available as options. The Ecoline series is a simplified version of the standard LED 025 light and has a dual cage clamp for connection instead of connectors. Nonetheless it is suitable for daisy-chaining and allows for up to 10 lights to be connected to each other.
02542.3-11 价格&库存
很抱歉,暂时无法提供与“02542.3-11”相匹配的价格&库存,您可以联系我们找货
