28TECHNICAL
28
HEATING
DATASHEET
COMPACT HIGH-PERFORMANCE FAN HEATER
CR 030 | 950 W
>>Compact design
>>Double insulated
>>Integrated thermostat or hygrostat
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
100
TECHNICAL DATA
168
105
145
130
Heating element
high performance cartridge
Temperature safety cut-out
with automatic reset and second-tier one shot fuse to protect
against overheating in case of fan failure
Heater body
extruded aluminium profile
Axial fan, ball bearing
airflow 160 m³/h, free flow
service life 50,000 h at +25 °C (+77 °F)
Connection
2-pole max. 2.5 mm², clamping screw with strain relief,
torque 0.8 Nm max.
Casing
plastic according to UL94 V-0, black
Mounting
screw fixing (M5)
Fitting position
vertical airflow (air outlet up)
Dimensions
168 x 145 x 100 mm
Weight
approx. 1.4 kg
Operating¹/Storage temperature
-45 to +70 °C (-49 to +158 °F)
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP20 / II (double insulated)
Note
other heating capacities from 200 W up available on request
¹ Operating temperature of heater with integrated hygrostat: 0 to +60 °C (+32 to +140 °F).
Connection diagram
Art. No.
Model
Operating voltage
Heating capacity
Recommended
pre-fuse T (time-delay)
03051.0-00
Fan Heater with thermostat
AC 230 V, 50/60 Hz
950 W
6.3 A
0 to +60 °C
VDE
UL File No. E234324
EAC
03051.0-02
Fan Heater with hygrostat
AC 230 V, 50/60 Hz
950 W
6.3 A
65 % RH, factory-set
VDE
UL File No. E234324
EAC
03059.9-00
AC 120 V, 50/60 Hz
950 W
10.0 A
+32 to +140 °F
UL File No. E234324
EAC
² Switch temperature difference 7 K (±4 K tolerance)
Setting range²
Approvals
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The compact high performance fan heater prevents formation of condensation and frost and provides an evenly
distributed interior air temperature in enclosures with electric/electronic components. The plastic housing provides
double insulation and acts as protection against contact. The fan heater is available with integrated thermostat
or pre-set hygrostat for temperature or humidity control. The CR 030 was designed as a stationary unit for the
bottom of the enclosure. For wall fixing the fan heater CR 130 is recommended.
很抱歉,暂时无法提供与“03051.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1772.753321+228.84760
- 10+1595.4954910+205.96510
- 国内价格
- 1+1655.37263
- 10+1489.84352
- 国内价格
- 1+2259.41733
- 25+2169.06688
- 50+2078.70602
- 100+2033.60369
