16TECHNICAL
16
HEATING
DATASHEET
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
SPACE-SAVING FAN HEATER
HV 031 / HVL 031 | 100 W to 400 W
>>Compact
>>Flat design
>>High air through-flow
>>Temperature safety cut-out
>>Clip fixing
TECHNICAL DATA
HV 031
Heater without fan (fan mounting kit included)
HVL 031
Heater with fan
Heating element
high performance cartridge
to protect against overheating in case of fan failure, automatic reset
Heater body
die-cast aluminium (glass bead blasted)
Connection
3-pole screw connector 2.5 mm², clamping torque 0.8 Nm max.
Connection casing
plastic according to UL94 V-0, black
Mounting
clip for 35 mm DIN rail, EN 60715
Fitting position
vertical airflow (air outlet up)
Operating/Storage temperature
-45 to +70 °C (-49 to +158 °F)
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP20 / I (earthed)
Approvals
UL File No. E187294, EAC
VDE only: 230 V
HVL 031 only:
Axial fan, ball bearing
airflow see table
service life 50,000 h at +25 °C (+77 °F)
Connection (axial fan)
2-pole screw connector 2.5 mm² (L2/N2)
a.) Clip
b.) Type plate
c.) Axial fan
d.) Air direction
Important note: Heater may only be operated together with fan.
Danger of overheating!
Art. No. HV 031
AC 230 C, 50/60 Hz
Art. No. HV 031
AC 120 V, 50/60 Hz
Heating capacity
Recommended pre-fuse T (time-delay)
AC 230 V
AC 120 V
Dimensions
Weight (approx.)
03100.0-00
03100.9-00
100 W
1.0 A
03101.0-00
03101.9-00
150 W
1.25 A
2.0 A
80 x 112 x 22 mm
0.4 kg
2.5 A
80 x 112 x 22 mm
03110.0-00
03110.9-00
200 W
0.4 kg
2.0 A
3.0 A
119 x 151 x 22 mm
0.5 kg
03111.0-00
03111.9-00
300 W
2.0 A
4.0 A
119 x 151 x 22 mm
0.5 kg
03112.0-00
03112.9-00
400 W
4.0 A
6.3 A
119 x 151 x 22 mm
0.5 kg
Art. No. HVL 031
AC 230 V, 50/60 Hz
Art. No. HVL 031
AC 120 V, 50/60 Hz
Heating capacity
AC 230 V
AC 120 V
Airflow min., free
flow
Dimensions
Weight (approx.)
03102.0-00
03102.9-00
100 W
1.0 A
2.0 A
35 m³/h
80 x 112 x 47 mm
0.6 kg
03103.0-00
03103.9-00
150 W
1.25 A
2.5 A
35 m³/h
80 x 112 x 47 mm
0.6 kg
03113.0-00
03113.9-00
200 W
2.0 A
3.0 A
108 m³/h
119 x 151 x 47 mm
0.9 kg
03114.0-00
03114.9-00
300 W
2.0 A
4.0 A
108 m³/h
119 x 151 x 47 mm
0.9 kg
03115.0-00
03115.9-00
400 W
4.0 A
6.3 A
108 m³/h
119 x 151 x 47 mm
0.9 kg
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
Compact high-performance fan heater prevents formation of condensation and frost and provides an evenly
distributed interior air temperature in enclosures with electric/electronic components. This fan heater may only be
operated together with a fan but is also available without fan for self-assembly (HV 031) and with pre-configured
fan (HVL 031).
很抱歉,暂时无法提供与“03110.0-00”相匹配的价格&库存,您可以联系我们找货
