03202.0-00
03202.0-00
    STEGO
    STEGO - 03202.0-00 - FAN HEATER, 1KW, -40 TO 158 DEG F, 240V
03202.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com COMPACT PTC FAN HEATER CS 032/CSF 032 | 1000 W >>Compact design >>High heating performance >>Double insulated plastic housing >>DIN or screw mount >>Optional integrated fixed thermostat CS 032 Fan Heater TECHNICAL DATA CSF 032 Fan Heater with Integrated Thermostat Heating element PTC resistor - temperature limiting Overheat protection built-in temperature limiter Surface temperature max. 176 °F (80 °C), except upper protective grille at 68 °F (20 °C) ambient temperature Air outlet temperature max. 257 °F (125 °C), 2" (50 mm) above grill Axial fan, ball bearing service life 70,000 h at 77 °F (25 °C) Air flow, free blowing 37 cfm (63 m³/h) Connection male power insert connector according to IEC320 C18 Housing plastic, UL 94V-0, black Mounting clip for 35 mm DIN rail, EN 60715 or screw mount (M5, not included), tightening torque 2 Nm max. Mounting position air flow directed up Operating / Storage temperature -40 to +140 °F (-40 to +60 °C) / -40 to +158 °F (-40 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions 5.9 x 3.5 x 2.6" (150.5 x 88 x 66 mm) Weight approx. 16.5 oz. (650 g) Protection class / Protection type II (double insulated) / IP20 Approvals UL File No. E234324, VDE, GOST TR Important note: Connectors and cables for electrical connection are not included with the heater. Connection cables are available as accessories. Part No. DIN rail mount Part No. screw mount Series Operating voltage 03209.0-00 03209.9-00 03209.0-01 CS 032, no thermostat AC 220-240 V, 50/60 Hz 03209.9-01 CS 032, no thermostat AC 100-120 V, 50/60 Hz 03201.0-00 03201.0-01 CSF 032, with thermostat AC 220-240 V, 50/60 Hz Heating capacity¹ Max. current (inrush) Switch-off temperature² Switch-on temperature² 1000 W 12 A - - 1000 W 18 A - - 1000 W 12 A 77 °F (25 °C) 59 °F (15 °C) 03201.9-00 03201.9-01 CSF 032, with thermostat AC 100-120 V, 50/60 Hz 1000 W 18 A 77 °F (25 °C) 59 °F (15 °C) 03202.0-00 03202.0-01 CSF 032, with thermostat AC 220-240 V, 50/60 Hz 1000 W 12 A 59 °F (15 °C) 41 °F (5 °C) 03202.9-00 03202.9-01 CSF 032, with thermostat AC 100-120 V, 50/60 Hz 1000 W 18 A 59 °F (15 °C) 41 °F (5 °C) ¹ at 77 °F (25 °C) ambient temperature; ² tolerance of ±5 K Note: Other Switch-off and Switch-on temperatures on request 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The compact CS 032 high performance fan heater prevents the formation of condensation and provides an evenly distributed interior air temperature in enclosures. The plastic housing provides protection against contact with current-carrying components via double insulation (protection class II). The fan heater is also available with an optional fixed-point thermostat as the CSF 032. These series were designed to accommodate DIN rail or screw mounting. www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com DIMENSIONAL DRAWING CS 032 Fan Heater View: back side DIN rail mount Heating Power (W) Screw mount Ambient Temperature ACCESSORIES Connection cable with female power insert connector according IEC320 C17 Part No. Length (L) 244379 1.0 m 244380 2.0 m Retaining Clip Photo: Retaining clip, Part No. 237009 Part No. Note 237009 Suitable for female power insert connector on connection cable 244379 and 244380 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. CSF 032 Fan Heater with Integrated Thermostat
03202.0-00 价格&库存
很抱歉,暂时无法提供与“03202.0-00”相匹配的价格&库存,您可以联系我们找货
