28412.0-00
28412.0-00
    STEGO
    STEGO - 28412.0-00 - Enclosure Accessory, Ventilation, Cable Gland, Enclosures & Switch Cabinets
28412.0-00 数据手册
TECHNICAL DATASHEET www.stegousa.com VENTILATION CABLE GLAND DAK 284 | IP66 / IP67 >>Cable gland with integrated ventilation >>High degree of protection >>Easy to install >>Integrated strain relief >>Waterproof filter >>Large clamping range TECHNICAL DATA Mounting thread M12 x 1.5 / M16 x 1.5 / M20 x 1.5 Enclosure wall thickness 0.02 - 0.12" (0.5 - 3 mm) with lock nut Material plastic, light grey Protection type IP66 / IP67 (EN 60529) Sealing sealing gasket NBR Filter PTFE Fitting position variable Operating/Storage temperature -4 to +176 °F (-20 to +80 °C) Approvals UL File No. E471430, VDE and EAC submitted Installation: Make hole cut-out in enclosure and secure ventilation cable gland with lock nut. Please make sure that the sealing gasket is put in place on the exterior side panel of the enclosure and the hole is free of burrs. D Thread Size M [mm] 1 External thread diameter Cable dia. clamping range D Length L M SW 2 SW 1 Part No. SW 1 L Hex nut dia. Torque Air permeability1 SW 1 SW 2 Lock nut Dome nut Weight 28410.0-00 M12 x 1.5 0.31" (8 mm) 0.48" (12.3 mm) 0.16 - 0.32" (4 - 8 mm) 0.74" (19 mm) 0.71" (18 mm) 2 Nm 2 Nm 25 l/h 0.25 oz. (7 g) 28411.0-00 M16 x 1.5 0.39" (10 mm) 0.64" (16.3 mm) 0.16 - 0.32" (4 - 8 mm) 0.74" (19 mm) 0.86" (22 mm) 2 Nm 2 Nm 25 l/h 0.28 oz. (8 g) 28412.0-00 M20 x 1.5 0.39" (10 mm) 0.8" (20.3 mm) 0.24 - 0.48" (6 - 12 mm) 0.94" (24 mm) 1.02" (26 mm) 5 Nm 5 Nm 40 l/h 0.46 oz. (13 g) at a pressure differential of 70 mbar (1psi) 12.01.2015 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Pressure differentials in enclosures with a high degree of protection are a result of internal and external temperature changes. In the case of negative pressure or partial vacuum, dust and humidity can enter the enclosure through the door seal. When the air inside the enclosure cools down, condensation may occur because the humidity cannot escape the enclosure. The innovative and easy-to-install ventilation cable gland DAK 284 enables secure cable entry into an enclosure with simultaneous pressure compensation (protection type IP66 / IP67). Even with a slight overpressure, a waterproof filter inside the gland allows the humidity to escape whilst blocking water and dirt from entering the enclosure.
28412.0-00
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离集成电路。
2. 器件简介:EL817是一个光隔离集成电路,用于实现输入和输出之间的电气隔离。
3. 引脚分配:EL817有8个引脚,包括Vcc、Vo、GND、A、B、C、D和E。
4. 参数特性:工作电压为5V,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817可以实现输入信号的光电隔离,保护电路不受干扰。
6. 应用信息:EL817广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:EL817采用DIP-8封装。
28412.0-00 价格&库存
很抱歉,暂时无法提供与“28412.0-00”相匹配的价格&库存,您可以联系我们找货
  • 1+63.806481+8.26030
  • 3+56.736273+7.34500
  • 10+49.4042010+6.39580
库存:51
