87 87
HAZARDOUS AREA THERMOSTAT
REx 011 | 15 °C, 25 °C (T6)
>>For areas with explosion hazard
>>High switching capacity
>>Compact Design
>>Set temperature
>>Ready-to-use with strain relief
>>Temperature class T6
www.stego.de | www.stego.co.uk | www.stegonorden.se
REGULATING
STEGO - PRODUCT
CATALOGUE
TECHNICAL
DATASHEET
TECHNICAL DATA
Temperature class
Ex Protection type
Gases
Dusts
30
45
5,4
II 2 GD
Ex db IIC T6 Gb
Ex tb IIIC T85°C Db IP66
Ambient temperature
-60 to +85 °C (-76 to +185 °F)
Sensor element
thermostatic bimetall
Service life
> 100,000 cycles
Max. switching capacity
AC 250 V 10 A1
Min. switching capacity
DC 1.5 V 5 mA
Max. inrush current
AC 16 A for 12 sec.
Connection
silicone cable (halogen-free) 3 x 1 mm², length 1 m
Connection PE
1.0 to 2.5 mm²
Mounting
clip for 35 mm DIN rail, EN 60715
screw fixing M5, optional widthwise mounting
Casing
aluminium, silver anodised
Dimensions
95 x 45 x 30 mm
Weight
approx. 0.3 kg
Fitting position
variable
Storage temperature
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP66 / I (earthed)
Approvals
EPS 16 ATEX 1 118 X
IECEx EPS 16.0054X
EAC
1000
95
25
5,4
T6
1
currents above 4 A affect the switch temperature difference
Art. No.
Contact type (1-pole)
Switch temperature
Switch temperature difference
01185.0-00
Contact breaker (NC)
+15 °C (±3 K tolerance)
5 K (±3 K tolerance)
01185.1-00
+25 °C (±3 K tolerance)
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
Compact, small mechanical thermostat offering a high response accuracy, small switch temperature difference,
and a very long service life (switching cycles). This thermostat of temperature class T6 (85 °C max.) is utilised for
the regulation of heaters deployed in areas with explosion hazard. The high switching performance allows direct
control of a heater.
很抱歉,暂时无法提供与“01185.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+848.187151+109.86990
- 3+793.403493+102.77350
- 10+738.7070710+95.68840
