Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
ELECTRONIC HYGROTHERM
ETF 012
>>Efficient temperature
& humidity control
>>Wide voltage range
>>Operating temperature down to -40 °C
>>High switching capacity
>>DIN rail mountable
TECHNICAL DATA
Switching difference (temperature)
2 K (±1 K tolerance) at +25 °C (+77 °F), 50 %RH
Switching difference (humidity)
4 %RH (±1 % tolerance) at +25 °C (+77 °F), 50 %RH
Reaction time (humidity)
approx. 5 sec.
Contact type
change-over contact (relay)
Service life
VDE: NO/NC > 15,000 cycles
UL: NO/NC > 30,000 cycles
Max. switching capacity (relay output)
10 A resistive / 1.6 A inductive @ AC 240 V
0.6 A @ DC 60 V¹
Max. inrush current
AC 30 A for 10 sec.
Connection
5-pole terminal, clamping torque 0.5 Nm max.:
solid/stranded² wire - AWG 14 max. (2.5 mm²)
Housing
plastic, UL 94V-0, light grey
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating/Storage temperature
-40 to +140 °F (-40 to +60 °C)
Operating/Storage humidity
max. 95 %RH (non-condensing)
Dimensions
3.0 x 2.4 x 1.7" (77 x 60 x 43 mm)
Weight
approx. 3.5 oz. (100 g)
Protection type
IP20
Approvals
UL File No. E164102, VDE, GOST-R
not UL confirmed
² When connecting with stranded wires, wire end ferrules must be used.
1
Hygrotherm
ETF 012
Heater
Heater
Wiring example
Part No.
Operating voltage
Setting range – temperature
Setting range – humidity
01230.0-00
AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V)
0 to +60 °C
50 to 90 %RH
01230.9-00
+32 to +140 °F
50 to 90 %RH
01230.1-00
DC 24-48 V (min. DC 20 V, max. DC 60 V)
0 to +60 °C
50 to 90 %RH
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The ETF 012 senses the ambient temperature and relative air humidity in an enclosure. Depending on which
contact combination is chosen, it then turns on or off a connected device if either the temperature is below or
the humidity is above the set point. The integrated LED in each adjustment knob is lit when indicating the active
function.
很抱歉,暂时无法提供与“01230.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+918.216591+114.88710
- 5+860.867575+107.71160
- 10+803.4282310+100.52480
- 国内价格
- 1+983.27450
- 5+963.98807
- 12+945.42020
- 25+930.65338
- 50+909.71115
