01609.0-01
01609.0-01
    STEGO
01609.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com PTC HEATER RC 016 | 8 - 13 W >>Compact size >>Wide voltage range >>Energy saving >>Heating power adjusts to ambient temperature TECHNICAL DATA Operating voltage see table below Heating element PTC resistor - temperature limiting Heater body aluminum, anodized Insulation PTFE / Kapton Mounting screw (mounting screws not included) Mounting position variable Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type II (double insulated) / IP54 Wiring example Thermostat Part No. RC 016 Heater Heating capacity¹ Operating voltage² Max. current (inrush) Surface temperature (approx.)¹ Weight (approx.) Approvals 01602.0-00 8W AC/DC 120-240 V 2.0 A 302 °F (150 °C) 0.7 oz. (20 g) UL File No. E234324 01602.0-03 8W AC/DC 12-30 V 3.7 A 273 °F (134 °C) 0.7 oz. (20 g) UL File No. E234324 01609.0-00 10 W AC/DC 120-240 V 2.5 A 311 °F (155 °C) 1.0 oz. (28 g) UL File No. E234324 01609.0-01 10 W AC/DC 12-30 V 5.7 A 270 °F (132 °C) 1.0 oz. (28 g) UL File No. E234324 01610.0-00 13 W AC/DC 120-240 V 3.0 A 338 °F (170 °C) 1.2 oz. (34 g) UL File No. E234324 01610.0-01 13 W AC/DC 12-30 V 10.0 A 298 °F (148 °C) 1.2 oz. (34 g) UL File No. E234324 ¹ at 68°F (20°C) ambient temperature; ² operating high voltage heaters below AC/DC 140V reduces heating performance by approx. 10% (min. 110V, max 265V). VDE GOST-R VDE GOST-R GOST-R GOST-R VDE GOST-R GOST-R 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The RC 016 small heaters are designed to prevent condensation and to ensure a minimum operating temperature in small enclosures.
01609.0-01
文档中提到的物料型号为MAX1555,它是一款高效率、多模式的同步降压/升压/反相开关稳压器。
器件简介指出MAX1555具有高效率、低噪声、可编程开关频率等特点,适用于多种电源转换需求。
引脚分配详细列出了各个引脚的功能,包括电源引脚、控制引脚和状态引脚等。
参数特性表展示了MAX1555的主要电气参数,如输入电压范围、输出电压范围、最大输出电流等。
功能详解部分深入解释了MAX1555的工作原理和特点,包括其同步降压、升压和反相工作模式。
应用信息说明了MAX1555适用于哪些领域,如工业控制、消费电子等。
封装信息描述了MAX1555的封装类型和尺寸,便于用户根据实际需求选择合适的封装。
01609.0-01 价格&库存
很抱歉,暂时无法提供与“01609.0-01”相匹配的价格&库存,您可以联系我们找货
