CR 027 PTC Fan Heater 400 - 650 W
Compact fan heater
Heating power adjusts to ambient temperature
Integrated adjustable thermostat
Built-in overheat protection
The semiconductor CR 027 fan heater prevents the formation of condensation and ensures an
even temperature in enclosures. The integrated thermostat is used to set the desired temperature while the high performance axial fan provides forced air circulation. The CR 027 is also
available with a continuously running fan (when powered).
Heating
DIN rail mountable
3.94” (100 mm)
Technical Data
5” (128 mm)
6.5” (165 mm)
4.8” (124 mm)
Wiring note: Only connect the L and N1 terminals - N2 is not
Heating element
PTC resistor - temperature limiting
Overheat protection
built-in temperature limiter
Axial fan, ball bearing
service life 50,000 h at 77 °F (25 °C)
Air flow, free blowing
see table below
Connection
2-pole terminal AWG 14 max. (2.5 mm²), torque 0.8 Nm max..
Housing
plastic, UL 94V-0, light grey
Optical indicator
thermostat control light
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Dimensions
6.5 x 3.94 x 5.0” (165 x 100 x 128 mm)
Protection class
II (double insulated)
Protection type
IP20
Approvals
UL File No. E204590
used and Grounding is not required
Heating Power / Ambient Temperature (@ 50 Hz)
Heating Power / Ambient Temperature (@ 60 Hz)
900
850
Heating Power (W)
Heating Power (W)
800
750
700
650
600
650W
550
500
550W
450
-20 °C
-4 °F
0 °C
32 °F
20 °C
68 °F
400
-40°C
-40 °C
-40°F
-40 °F
40 °C
104 °F
Part No.
02700.0-00
02701.0-00
02700.9-00
02701.9-00
1) at
Heating
(@ 50 Hz)
475 W
550 W
400 W
510 W
00°C
°C
32°F
32
°F
20°C
°C
68°F
68 °F
4040°C
°C
104°F
104
°F
Temperature
Temperature
capacity1)
-20°C
-20
°C
-4°F
-4 °F
capacity1)
Heating
(@ 60 Hz)
550 W
650 W
550 W
650 W
AC 220-240 V
AC 220-240 V
Max. current
(inrush)
11.0 A
13.0 A
Air flow,
free blowing
20 cfm (35 m³/h)
26 cfm (45 m³/h)
Thermostat
setting range
0 to 60 °C
0 to 60 °C
Weight
(approx.)
2.0 lbs. (0.9 kg )
2.4 lbs (1.1 kg)
AC 100-120 V
AC 100-120 V
14.0 A
15.0 A
20 cfm (35 m³/h)
26 cfm (45 m³/h)
32 to 140 °F
32 to 140 °F
2.0 lbs. (0.9 kg )
2.4 lbs (1.1 kg)
Operating voltage
68 °F (20 °C) ambient temperature
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application.
STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
CR027/11-12/US
-40 °C
-40 °F
很抱歉,暂时无法提供与“02700.9-00”相匹配的价格&库存,您可以联系我们找货
