02700.9-02
    STEGO
02700.9-02 数据手册
Solutions Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com PTC FAN HEATER CR 027 | 400 - 650 W www.stegousa.com direct www.solutionsdirectonline.com >>Compact fan heater >>Heating power adjusts to ambient temperature >>Integrated adjustable thermostat >>Built-in overheat protection >>DIN rail mountable TECHNICAL DATA Heating element PTC resistor - temperature limiting Overheat protection built-in temperature limiter Axial fan, ball bearing service life 50,000 h at 77 °F (25 °C) Air flow, free blowing see table below Connection 2-pole terminal AWG 14 max. (2.5 mm²), torque 0.8 Nm max. Housing plastic, UL 94V-0, light grey Function control light LED Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions 6.5 x 3.94 x 5.0” (165 x 100 x 128 mm) Protection class / Protection type II (double insulated) / IP20 Approvals UL File No. E204590, VDE, GOST TR Heating Power (W) Heating Power / Ambient Temperature (@ 60 Hz) Heating Power (W) Heating Power / Ambient Temperature (@ 50 Hz) Temperature Part No. Temperature Heating capacity¹ (@ 50 Hz) Heating capacity¹ (@ 60 Hz) Operating voltage Max. current (inrush) Air flow, free blowing 02700.0-00 475 W 550 W 02700.9-00 400 W 550 W 02701.0-00 550 W 02701.9-00 510 W AC 220-240 V 11.0 A AC 100-120 V 14.0 A 650 W AC 220-240 V 650 W AC 100-120 V ¹ at 68 °F (20 °C) ambient temperature; ² Switch temperature difference 7K (±4K tolerance) Note: Only connect the L and N1 terminals - N2 is not used and grounding is not required. Thermostat setting range² Weight (approx.) 20 cfm (35 m³/h) 0 to 60 °C 2.0 lbs (0.9 kg ) 20 cfm (35 m³/h) 32 to 140 °F 2.0 lbs (0.9 kg ) 13.0 A 26 cfm (45 m³/h) 0 to 60 °C 2.4 lbs (1.1 kg) 15.0 A 26 cfm (45 m³/h) 32 to 140 °F 2.4 lbs (1.1 kg) 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The semiconductor CR 027 fan heater prevents the formation of condensation and ensures an even temperature in enclosures. The integrated thermostat is used to set the desired temperature while the high performance axial fan provides forced air circulation. The CR 027 is also available with a continuously running fan (when powered).
02700.9-02 价格&库存
很抱歉,暂时无法提供与“02700.9-02”相匹配的价格&库存,您可以联系我们找货
