24
HEATING
TECHNICAL
DATASHEET
SPACE-SAVING FAN HEATER
HVI 030 | 500W to 700W
>>Compact
>>Flat design
>>Temperature safety cut-out
>>Twist clip or screw fixing
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
TECHNICAL DATA
View: back side
Twist clip fixing
Heating element
high performance cartridge
with automatic reset and second-tier one shot fuse
to protect against overheating in case of fan failure
Connection
2-pole dual pressure clamp for rigid wire 2.5mm², stranded wire
(with wire end ferrule) 1.5mm²
Casing
plastic according to UL94 V-0, black
Mounting
twist clip for 35mm DIN rail, EN 60715 or
screw fixing (M6), torque 2Nm max., washers have to be used
Fitting position
vertical airflow (air outlet up)
Dimensions
169 x 127 x 45mm
Weight
approx. 0.7kg
Operating/Storage temperature
-40 to +50°C (-40 to +122°F)/-45 to +70°C (-49 to +158°F)
Operating/Storage humidity
max. 90% RH (non-condensing)
Protection type/Protection class
IP20 / II (double insulated)
Approvals
VDE; UL submitted
Note
other heating capacities and voltages available on request
Screw fixing
Important note: Heater may only be operated together with fan (min.
150m³/h). Danger of overheating!
Art. No. twist clip fixing
Art. No. screw fixing
Operating voltage
Heating capacity
Pre-fuse T (time-delay)
03074.0-00
03074.0-01
230VAC, 50/60Hz
500W
3.15A
03073.0-00
03073.0-01
230VAC, 50/60Hz
600W
3.15A
03072.0-00
03072.0-01
230VAC, 50/60Hz
700W
4A
03074.9-00
03074.9-01
120VAC, 50/60Hz
500W
6.3A
03073.9-00
03073.9-01
120VAC, 50/60Hz
600W
6.3A
03072.9-00
03072.9-01
120VAC, 50/60Hz
700W
8A
20.03.2013 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The compact high-performance fan heater prevents formation of condensation and frost and provides an evenly
distributed interior air temperature in enclosures with electric/electronic components. The heater may only be
operated together with fan, but is also available without axial fan (for self-installation). The fan heaters are available
with two different mounting systems – either mounting by screw fixing or with a new and unique twist clip mounting
system. These options allow for a quick and easy installation of the fan heater.
很抱歉,暂时无法提供与“03074.0-00”相匹配的价格&库存,您可以联系我们找货
