04641.0-00
04641.0-00
    STEGO
04641.0-00 数据手册
17 17 www.stego.de | www.stego.co.uk | www.stegonorden.se HEATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET COMPACT FAN HEATER HGL 046 | 250 W, 400 W >>Compact Design >>Clip fixing >>Long service life >>Temperature safety cut-out TECHNICAL DATA View from below Heating element resistance heater Temperature safety cut-out to protect against overheating in case of fan failure, automatic reset Heater body anodised extruded aluminium profile Surface temperature max. +75 °C (400 W) Axial fan, ball bearing Airflow, free flow 45 m³/h (50 Hz) or 54 m³/h (60 Hz) service life 50,000 h at +25 °C (+77 °F) Connection internal connection terminal 1.5 mm² with strain relief, clamping torque 0.8 Nm max. Connection casing plastic according to UL94 V-0, black Mounting clip for 35 mm DIN rail, EN 60715 Fitting position vertical airflow (air outlet up) Operating/Storage temperature -45 to +70 °C (-49 to +158 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP20 / I (earthed) Note other voltages on request Example of connection Control contact e.g. thermostat KTO 011 L N Heater Fan heater HGL 046 (AC 230 V and AC 120 V) with temperature safety cut-out L N Art. No. Operating voltage Heating capacity Recommended pre-fuse T (time-delay) Length (L) Weight (approx.) 04640.0-00 AC 230 V, 50/60 Hz 250 W 2.0 A 182 mm 1.1 kg VDE UL File No. E150057¹ EAC 04641.0-00 AC 230 V, 50/60 Hz 400 W 4.0 A 222 mm 1.4 kg VDE UL File No. E150057¹ EAC 04640.9-00 AC 120 V, 50/60 Hz 250 W 4.0 A 182 mm 1.1 kg VDE UL File No. E150057¹ EAC 04641.9-00 AC 120 V, 50/60 Hz 400 W 6.3 A 222 mm 1.4 kg VDE UL File No. E150057¹ EAC ¹ according to UL 508A, NITW File on request Approvals 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Compact fan heater prevents formation of condensation and frost. The integrated high-performance axial fan provides an evenly distributed interior air temperature in enclosures with electric/electronic components.
04641.0-00 价格&库存
很抱歉,暂时无法提供与“04641.0-00”相匹配的价格&库存,您可以联系我们找货
    • 1+1081.53946
    库存:4
