Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
FLAT HEATER
CP 061 | 50 W, 100 W
>>Screw fixing
>>Linear expansion compensation
>>Integrated temperature cut-out
>>Ready-to-use with strain relief
The Flat Heater CP 061 is used to provide evenly distributed temperature within enclosures and cabinets with
electric/electronic components. Its ultra-thin design makes it particularly suitable for high-density applications
in which standard enclosure heaters are often too big. Depending on the application, the Flat Heater can be used
as a convection heater or as a contact heater. When used as a contact heater it offers thermoconductive contact
to a component or a cabinet wall. Additionally, a mounting system especially designed for the CP 061 allows for
the compensation of an expansion of the heater body as a result of the heating-up when in operation. Operated
as a convection heater, the slim heater CP 061 warms up the ambient air within a cabinet. The CP 061 is designed
for continuous operation.
TECHNICAL DATA
Heating element
resistance heater
Overheat protection
with automatic reset
Heating body
Surface temperature
aluminum profile
max. +302 °F (+150 °C) at +77 °F (+25 °C)
Connection
silicone cable (halogen-free) 3 x AWG 18 (0.75 mm²),
length 3 ft (1 m)
Housing
plastic, UL 94V-0, black
Mounting
screw mount (M6)
Mouning position
horizontal, variable connection or
vertical, connection on bottom
Dimensions
L x 4" x .32" (L x 100 x 8 mm)
Operating / Storage temperature
-40 to +140 °F (-40 to +60 °C) / -40 to +185 °F (-40 to +85 °C)
Operating / Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP30 / I (earthed)
Note
other voltages (AC 120 V) available upon request
Wiring example
Part No.
Operating voltage
Heating capacity
Length (L)
Hole spacing (X)
Weight approx.
06100.0-00
AC 230 V, 50/60 Hz
50 W
9.41" (239 mm)
8.9" (225 mm)
.88 lbs (0.4 kg)
VDE
Approvals
EAC
06101.0-00
AC 230 V, 50/60 Hz
100 W
16.3" (414 mm)
15.75" (400 mm)
1.54 lbs (0.7 kg)
VDE
EAC
09.04.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
>>Contact/Convection heater
>>Ultra flat design
>>Compact
>>Easy, firm installation
很抱歉,暂时无法提供与“06100.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1069.849451+138.10860
- 5+709.468985+91.58650
- 国内价格
- 1+1094.83793
- 5+1051.03734
- 10+1007.24715
