07301.0-00
07301.0-00
    STEGO
    STEGO - 07301.0-00 - PRESS & TEMP SENSOR, ABSOLUTE, 1.1KPA
07301.0-00 数据手册
2 TECHNICAL 2 DATASHEET www.stego-connect.com www.stego.de PRODUKTKATALOG - STEGO SENSOR HUB & SENSORS SHC 071 | IO-Link, DC 24 V, 4 Sensor Ports > For 1 to 4 digital STEGO sensors > Quick connection of sensors via connectors > 4 sensor types The IO-Link Sensor Hub SHC 071 records measuring data from up to four external non IO-Link STEGO sensors on a process level and transmits data via an IO-Link Master for control and monitoring applications, using options such as an edge computer, cloud based system or PLC. Standard IO-Link sensors are connected to one IO-Link Master port each. By using the Sensor Hub up to four external sensors can be connected, but they only use one IO-Link Master port (see illustrations Connection Comparison). This allows you to attach up to three more IO-Link devices to an IO-Link Master. The Sensor Hub SHC 071 comes with a universal mounting bracket which offers six different DIN rail or screw mounting options (see operating instructions). Combined with other digital field devices and the STEGO CONNECT platform, the Sensor Hub can be part of a powerful IO-Link IIoT system. Please visit our website on www.stego-connect.com for more information. TECHNICAL DATA 1 Sensor connection 4 ports with strain relief for up to 4 STEGO sensors1 IO-Link connection M12 round plug connector, IEC 61076-2-101, 4-pin, A-coded Electrical protection Reverse-polarity, short circuit, overvoltage protection Mounting clip for 35 mm DIN rail, EN 60715 and screw mounting (M5) Casing plastic according to UL94 V-0, light grey Dimensions 107 x 35 x 79 mm (87 mm with universal mounting bracket) Weight approx. 110 g Fitting position variable Operating/Storage temperature -40 to +80 °C (-40 to +176 °F) / -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Operating altitude ≤ 4,000 m above sea level Protection type/Protection class IP40 / III (SELV) Certificates CB No. DE1-63389 In conformity with IEC 61010-1 Evaluated in accordance with UL und CSA standards Please order STEGO sensors separately. Universal mounting bracket for DIN rail and screw mounting Example of connection Art. No. Interface Operating voltage Power consumption max. 07100.2-00 IO-Link (digital, specified acc. to version 1.1) DC 24 V (DC 18-30 V) 0.5 W 30.08.2018||Specifi 03.12.2020 Technische cations Änderungen are subjectvorbehalten. to change without Alle Angaben notice.ohne ErrorsGewähr. and omissions Die genannten excepted. Informationen Suitability ofentbinden this product denfor Kunden its intended nicht von useselbstständigen and any associated Applikationsprüfungen. risks must be determined by the end customer/buyer in its final application. > Digital IO-Link Interface > Small dimensions > Easy DIN rail and screw mounting > M12 plug-in connector DIGITAL PLUG & CONNECT SENSORS FOR IO-LINK SENSOR HUB SHC 071 The IO-Link Sensor Hub SHC 071 does not come with sensors and connection cables, these need to be ordered separately. The digital Plug & Connect sensors listed below are suitable for connection with the sensor hub. The sensors are pre-calibrated and ready for use; there is no need for individual calibration. Their small dimensions and offering of different cable lengths allow flexible positioning and easy mounting, mounting clips included. www.stego-connect.com www.stego.de 3 3 STEGO - PRODUKTKATALOG TECHNICAL DATASHEET DIGITAL PLUG & CONNECT TEMPERATURE AND HUMIDITY SENSOR SEN 073, IP20 Mounting clip for 35 mm DIN rail, EN 60715 and screw mounting (M4) Casing plastic according to UL94 V-0, black Dimensions/Weight 59 x 12 x 13 mm Fitting position variable Response time T63 1.5 min. (Temperature), 7 sec. (Humidity) Operating/Storage temperature -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity 100 % RH / max. 90 % RH (non-condensing) Operating altitude ≤ 4,000 m above sea level Art. No. Sensor Connection Temperature measuring range Humidity measuring range Weight (approx.) Protection type 07300.1-00 Temperature + rel. Humidity cable with connector, shielded, 1.0 m -40 to +80 °C (-40 to +176 °F) ±0.2 K 0 to 100 % RH ±2 % 40 g IP20 07300.1-01 Temperature + rel. Humidity cable with connector, shielded, 2.0 m -40 to +80 °C (-40 to +176 °F) ±0.2 K 0 to 100 % RH ±2 % 70 g IP20 DIGITAL PLUG & CONNECT TEMPERATURE AND HUMIDITY SENSOR SEN 073, IP64 TECHNICAL DATA Mounting incl. mounting clip for screw mounting, Ø 3 mm, see photo Casing stainless steel Dimensions/Weight 33.5 x Ø 20 mm / approx. 25 g Fitting position variable Response time T63 2 min. (Temperature), 20 sec. (Humidity) Operating/Storage temperature -40 to +70 °C (-40 to +158 °F) / -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity 100 % RH / max. 90 % RH (non-condensing) Operating altitude ≤ 4,000 m above sea level Art. No. Sensor Temperature measuring range Humidity measuring range Connection Protection type 07300.0-00 Temperature + relative Humidity -40 to +70 °C (-40 to +158 °F) ±0.2 K 0 to 100 % RH ±2 % M12 plug IEC 61076-2-101, 4-pin, A-coded IP64 Photo: Mounting clip for screw mounting, Ø 3 mm (included) DIGITAL PLUG & CONNECT PRESSURE AND TEMPERATURE SENSOR SEN 073, IP64 TECHNICAL DATA 1 2 Mounting incl. mounting clip for screw mounting, Ø 3 mm, see photo Casing stainless steel Dimensions/Weight 33.5 x Ø 20 mm / approx. 25 g Fitting position variable Response time T63 5 sec. (Absolute Pressure), 2.5 min. (Temperature) Operating/Storage temperature -40 to +70 °C (-40 to +158 °F) / -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity 100 % RH / max. 90 % RH (non-condensing) Operating altitude ≤ 4,000 m above sea level Art. No. Sensor Pressure measuring range1 Temperature measuring range2 Connection Protection type 07301.0-00 Absolute Pressure + Temperature 300 to 1100 hPa -40 to +70 °C (-40 to +158 °F) M12 plug IEC 61076-2-101, 4-pin, A-coded IP64 Resolution: 0.1 hPa; Accuracy, absolute: ±1.7 hPa within temperature range -20 to 0°C (-4 to +32 °F), ±1.0 hPa within temperature range 0 to +65°C (+32 to +149 °F); Resolution: 0,1 °C; Accuracy, absolute: ±1.0 °C within temperature range 0 to +65°C (+32 to +149 °F), ±0.5 °C at +25 °C (+77 °F); 06.03.2019 || Specifications 03.12.2020 Technische Änderungen are subjectvorbehalten. to change without Alle Angaben notice.ohne ErrorsGewähr. and omissions Die genannten excepted. Informationen Suitability ofentbinden this product denfor Kunden its intended nicht von useselbstständigen and any associated Applikationsprüfungen. risks must be determined by the end customer/buyer in its final application. TECHNICAL DATA 4 TECHNICAL 4 DATASHEET www.stego-connect.com www.stego.de PRODUKTKATALOG - STEGO DIGITAL PLUG & CONNECT LIGHT SENSOR SEN 073 In 2021 we can also offer an ambient light sensor, measuring the intensity of visible light. The spectral response of the sensor will tightly match the photopic response of the human eye. Please contact us for more information. Sensor Illuminance range Accuracy, relative Connection Visible Light 0.01 to 83,865 lx 0.2 % M12 plug IEC 61076-2-101, 4-pin, A-coded CABLES These cables are needed for the connection of the IO-Link Sensor Hub SHC 071 and the digital Plug & Connect Sensors SEN 073 Temperature and Humidity IP64 (Art. No. 07300.0-00) and Pressure and Temperature IP64 (Art. No. 07301.0-00). The standard cable is 2.0 m long and fully assembled. Sensor cables in lengths of 5.0 m and 20.0 m can be ordered for individual adjustments of the cable length for an application. Art. No. 244445 244446 244447 Cable Sensor cable with connector, interlocking, shielded Connection 2.0 m fully assembled with female M12 plug IEC 61076-2-101, 4-pin, A-coded, shielded 5.0 m for self-assembly, incl. female M12 plug IEC 61076-2-101, 4-pin, A-coded, shielded 20.0 m for self-assembly, incl. female M12 plug IEC 61076-2-101, 4-pin, A-coded, shielded Photo: Fully assembled sensor cable with connector and female M12 plug, 2.0 m long (Art. No. 244445) 1 2 Length 3 Photo: Sensor cable with connector incl. female M12 plug for self-assembly, 5.0 m long (Art. No. 244446) and 20.0 m long (Art. No. 244447) CONNECTION EXAMPLE The illustration shows the IO-Link Sensor Hub SHC 071 with different sensors and connection cables (from top down): (1) Cable with connector and female M12 plug in 2.0 m length (Art. No. 244445) (2) Cable with connector in 5.0 m length (Art. No. 244446) and (3) 20.0 m length (Art. No. 244447), each incl. (4) female M12 plug for self-assembly (5) Temperature and Humidity Sensor SEN 073, IP20, in 1.0 m or 2.0 m cable length with connector 30.08.2018||Specifi 03.12.2020 Technische cations Änderungen are subjectvorbehalten. to change without Alle Angaben notice.ohne ErrorsGewähr. and omissions Die genannten excepted. Informationen Suitability ofentbinden this product denfor Kunden its intended nicht von useselbstständigen and any associated Applikationsprüfungen. risks must be determined by the end customer/buyer in its final application. ACCESSORIES FOR DIGITAL PLUG & CONNECT SENSORS SEN 073 CONNECTION COMPARISON IO-LINK SENSOR HUB SHC 071 VS. IO-LINK SENSORS Even with four external sensors connected, the Sensor Hub SHC 071 only uses one IO-Link Master port. This may possibly add a (cost) savings effect on the port capacities of the IO-Link Master. The illustrations also show that the cable lengths can be extended from 20 m to 2 x 20 m when using the Sensor Hub. www.stego-connect.com www.stego.de 5 5 STEGO - PRODUKTKATALOG TECHNICAL DATASHEET IO-Link Master IO-Link Master ≤ 20 m IO-Link Sensor Hub SHC 071 ≤ 20 m 4 x IO-Link Smart Sensors CSS 014 Digital Plug & Connect Sensors SEN 073 for IO-Link Sensor Hub SHC 071 06.03.2019 || Specifications 03.12.2020 Technische Änderungen are subjectvorbehalten. to change without Alle Angaben notice.ohne ErrorsGewähr. and omissions Die genannten excepted. Informationen Suitability ofentbinden this product denfor Kunden its intended nicht von useselbstständigen and any associated Applikationsprüfungen. risks must be determined by the end customer/buyer in its final application. ≤ 20 m
07301.0-00
物料型号: - 型号:07100.2-00
器件简介: - IO-Link Sensor Hub SHC 071是一个数字IO-Link接口,适用于1到4个数字STEGO传感器,具有小尺寸和易于安装的特点。
引脚分配: - 传感器连接:4个端口,每个端口可连接1个STEGO传感器。 - IO-Link连接:M12圆形插头连接器,IEC61076-2-101标准,4针A编码。
参数特性: - 工作电压:DC 24V(DC 18-30V)。 - 最大功耗:0.5W。 - 电气保护:防反接、短路和过电压保护。 - 外壳材料:UL94 V-0标准塑料,浅灰色。
功能详解: - 记录来自最多四个外部非IO-Link STEGO传感器的测量数据,并通过IO-Link Master传输数据。 - 通过使用Sensor Hub,可以连接四个外部传感器,但仅使用一个IO-Link Master端口,从而可以在IO-Link Master上连接多达三个额外的IO-Link设备。
应用信息: - 适用于控制和监控应用,例如边缘计算机、基于云的系统或PLC。
封装信息: - 尺寸:107x35x79mm(含通用安装支架为87mm)。 - 重量:约110g。 - 工作/存储温度:-40°C至+80°C(-40°F至+176°F)。 - 工作/存储湿度:最大90% RH(不凝结)。 - 工作海拔:海拔4000米以下。 - 保护类型/保护等级:IP40/I(SELV)。
07301.0-00 价格&库存
很抱歉,暂时无法提供与“07301.0-00”相匹配的价格&库存,您可以联系我们找货
