2 TECHNICAL
2
DATASHEET
www.stego-connect.com
www.stego.de
PRODUKTKATALOG - STEGO
STEGO CONNECT IO-LINK MASTER
SCM 074 | IO-Link Master with IoT Interface by ifm
> For connection of up to 4 IO-Link
Devices
> Robust housing for use in harsh
industrial environments
The IO-Link Master SCM 074 by ifm establishes the connection between IO-Link devices (digital field devices) and
the STEGO CONNECT Edge Box SCE 074 to transmit data into the STEGO CONNECT cloud. It works bi-directional,
i.e. sends and receives data. STEGO CONNECT is a cloud-based IIoT platform connecting digital field devices with
the web using the IO-Link communication protocol. IO-Link is a point-to-point protocol (PPP), it communicates
between two separate endpoints or nodes. With the easy setup and the use of IO-Link devices, such as IOLink sensors and actuators, in combination with the STEGO CONNECT software, you can move analog processes
into the digital world without programming skills. Further information about the IO-Link IIoT platform STEGO
CONNECT can be found on www.stego-connect.com.
TECHNICAL DATA
MECHANICAL DATA
Materials
Housing
Socket
PA
brass nickel-plated
Weight
295 g
OPERATING CONDITIONS
Ambient Temperature
-25 to +60 °C (-13 to +140 °F)
Storage Temperature
-25 to +85 °C (-13 to +185 °F)
Max. relative air humidity
90 %
Protection
IP 65; IP 66; IP 67
Degree of soiling
2
Connection Examples
IO-Link Master
IO-Link Master
≤ 20 m
IO-Link Sensor Hub
SHC 071
≤ 20 m
≤ 20 m
4 x IO-Link Smart Sensors
CSS 014
Digital Plug & Connect Sensors SEN 073
for IO-Link Sensor Hub SHC 071
Art. No.
Inputs / Outputs (configurable)
Operating Voltage
Current Consumption
Protection Class
07401.0-00
Number of digital inputs: 8; Number of digital outputs: 4
20...30 VDC; (US; to SELV/PELV)
300...3900 mA; (US)
III
30.08.2018||Specifications
03.12.2020
Technische Änderungen
are subjectvorbehalten.
to change without
Alle Angaben
notice.ohne
ErrorsGewähr.
and omissions
Die genannten
excepted.
Informationen
Suitability ofentbinden
this product
denfor
Kunden
its intended
nicht von
useselbstständigen
and any associated
Applikationsprüfungen.
risks must be determined by the end customer/buyer in its final application.
> Reliable transmission of data to the IT
environment
> Ethernet & IO-Link communication
interfaces
3 3
www.stego.de
STEGO - PRODUKTKATALOG
TECHNICAL
DATASHEET
TESTS / APPROVALS
EMC
EN 61000-6-2
EN 61000-6-4
Shock resistance
DIN EN 60068-2-27
Vibration resistance
DIN EN 60068-2-64
DIN EN 60068-2-6
8; (IO-Link Port Class A: 4 x 2)
Switching level high
11...30 V
Switching level low
0...5 V
Digital inputs protected against short circuits
yes
OUTPUTS
4; (IO-Link Port Class A: 4 x 1)
Max. current load per output
300 mA
Short-circuit proof
yes
INTERFACES
Communication interface
Ethernet; IO-Link
ETHERNET - INTERNET OF THINGS
Transmission standard
10Base-T; 100Base-TX
Transmission rate
10; 100 Mbit/s
Protocol
MQTT JSON
Factory settings
IP address: 169.254.x.x
subnet mask: 255.255.0.0
gateway IP address: 0.0.0.0
MAC address: see type label
Note on interfaces
Secure protocol; HTTPS
IO-LINK MASTER
Transmission type
COM1 (4,8 kBaud); COM2 (38,4 kBaud); COM3 (230,4 kBaud)
IO-Link revision
1.1
Number of ports class A
4
Electrical connection - Ethernet
IoT X21, X22
ELECTRICAL CONNECTION - ETHERNET
1
TX +
2 X21, X22
IOT
RX +
3
TX -
24
RX -
RX +
35
not used
TX -
1
4
5
Connector: M12
Connector: M12
Electrical connection - Process connection
IO-Link Port Class A X01...X04
TX +
RX not used
03.12.2020 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
INPUTS
4 TECHNICAL
4
DATASHEET
25
not used
www.stego.de
1
Sensorversorgung (US) L+
2
digital input
3
Sensorversorgung (US) L1
ELECTRICAL
CONNECTION
4
C/Q- PROCESS
IO-Link CONNECTION
2
digital input
5
not used
3
(US) LIO-LINK
PORT CLASS ASensorversorgung
X01...X04
Connector: M12
C/Q IO-Link
14
Sensor supply (US) L+
digital input
3
Sensor supply (US) L-
4
C/Q IO-Link
5
not used
Connector: M12
X31 Connector: M12
1
+ 24 V DC (US)
ElectricalCONNECTION
connection -- VOLTAGE
voltage SUPPLY
supply
ELECTRICAL
2
not used
X31
3
GND (US)
X31
1
+ 24 V DC (US)
not used
14
2
not used
2 Connector: M12
3
GND (US)
+ 24 V DC (US)
not used
3
44
GND (US)
not used
not used
Connector: M12
Connector: M12
REMARKS
Remarks
For further information please see the manufacturer operating instructions.
(ifm AL1350-00 www.ifm.com)
Pack quantity
1 pcs.
ACCESSORIES FOR IO-LINK MASTER SCM 074
CONNECTION CABLES
These cables are needed to connect the IO-Link Master SCM 074 to the STEGO CONNECT Edge Box SCE 074 (Art. No. 07400.0-00), and to an IO-Link device, for example our IO-Link Smart Sensor
CSS 014 for temperature and humidity (Art. No. 01411.2-00).
Art. No.
Use
Cable
Length
Connection
244449
IO-Link Master SCM 074 - Edge Box SCE 074
connection cable
free of silicones and halogens, shielded
2.0 m
fully assembled with male M12 plug on RJ45 plug
244451
IO-Link Master SCM 074 - IO-Link Device
connection cable, free of silicones and halogens
2.0 m
fully assembled with male M12 plug on female M12 plug
Connection cable Art. No. 244449
IO-Link Master SCM 074 to Edge Box SCE 074
Connection cable Art. No. 244451
IO-Link Master SCM 074 to IO-Link Device
03.12.2020
to change without
Alle Angaben
notice.ohne
ErrorsGewähr.
and omissions
Die genannten
excepted.
Informationen
this product
denfor
Kunden
its intended
nicht von
useselbstständigen
and any associated
Electrical connection - voltage supply
很抱歉,暂时无法提供与“07401.0-00”相匹配的价格&库存,您可以联系我们找货
