08673.0-00
08673.0-00
    STEGO
    STEGO - 08673.0-00 - HOSE PROOF HOOD, IP56, FILTER FAN
08673.0-00 数据手册
62TECHNICAL 62 COOLING DATASHEET >>Increase of protection class >>Easy to clean >>Filter mat change from outside >>Impact-resistant, robust >>Safe against unauthorized removal >>Weather resistant >>Versatile >>Protective grid The hose-proof hood for increasing the protection class is a protective cover for filter fans, intake and exit filters, e.g. for the series FPI 018, FPO 018 and FF 018. It is used for protection against water projected by a hose and extreme climatic influences if located outdoors or in industrial applications with harsh environmental conditions. In order to clean the filter fans or to change the filter mat, the hood can easily be removed, the cabinet does not need to be opened (safety risk). TECHNICAL DATA B L 30° 1 Material hood VA, polished Material sealing Silicone, food safe Protection type IP561 Protection type UL/NEMA UL Type 4/4x1 / Nema Type 4/4x1 Approval UL File No. E234324, EAC When used with STEGO filter fans FPI/FPO 018 and FF 018 and when seal is tightly fitted. B H Security thread M6 Back view Art. No. Cutout usable for FF 018 Cutout usable for FPI/FPO 018 Dimensions LxBxH Max. covered area (X x Y) Weight (approx.) 0.8 kg 08670.0-00 97 x 97 mm 92 x 92 mm 214 x 195 x 48 mm 143 x 132 mm 08671.0-00 125 x 125 mm 124 x 124 mm 279 x 225 x 58 mm 173 x 168 mm 1.2 kg 08672.0-00 176 x 176 mm 176 x 176 mm 359 x 294 x 68 mm 235 x 221 mm 2.0 kg 08673.0-00 250 x 250 mm 223 x 223 mm 415 x 369 x 78 mm 290 x 288 mm 2.8 kg 08674.0-00 - 291 x 291 mm 485 x 409 x 103 mm 340 x 328 mm 3.7 kg 20.07.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. HOSE-PROOF HOOD FFH 086 | IP56 www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO
08673.0-00 价格&库存
很抱歉,暂时无法提供与“08673.0-00”相匹配的价格&库存,您可以联系我们找货
