11101.9-01
11101.9-01
    STEGO
11101.9-01 数据手册
2 TECHNICAL 2 REGULATING DATASHEET www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO SMALL COMPACT THERMOSTAT KTO 111 / KTS 111 > Safe wiring with Push-In connection terminal > Faster and tool-free wiring > Improved air intakes for ventilation > Easy adjustability of switch temperature setting > for use in up to 5,000 m altitude KTO 111: Thermostat (NC); contact breaker for regulating heaters. The contact opens when temperature is rising. KTS 111: Thermostat (NO); contact maker for regulating of filter fans and heat exchangers or for switching signal devises when temperature limit has been exceeded. The contact closes when temperature is rising. TECHNICAL DATA Connection diagrams Thermostat KTO 111 (NC) Thermostat KTS 111 (NO) Switch temperature difference 7 K (±4 K tolerance) Sensor element thermostatic bimetal Contact type snap-action contact Service life 100,000 cycles verified Max. operating voltage, frequency range AC 250 V, 50-60 Hz Max. inrush current AC 16 A for 10 sec. Connection1 2 Push-In clamps rigid wire 2.5 mm² (AWG 14) stranded wire 1.5 mm² (AWG 16) Mounting clip for 35 mm DIN rail, EN 60715 Casing plastic according to UL94 V-0, light grey Dimensions 60 x 33 x 41 mm Weight approx. 40 g Fitting position variable Operating/Storage temperature -45 to +80 °C (-49 to +176 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP20 / II Overvoltage category/Altitude II: up to 5,000 m; III: up to 2,000 m ¹ Stripped length of rigid wire: 10 to 12 mm. When connecting with wires, wire end ferrules must be used (square or trapezoid crimp). Length of wire end ferrule: 10 mm or 12 mm. Important note: The contact system of the regulator is subjected to environmental influences, thus the contact resistance may change. This can lead to a voltage drop and/or self-heating of the contacts. Thermostat KTO 111 (NC) Heater Thermostat KTS 111 (NO) e.g. Fan Thermostat e.g. Signal device KTS 111 (NO) Examples of connection Heater Filter fan, Cooling equipment, Signal device Setting range 2 Art. No. Contact breaker (NC) Art. No. Contact maker (NO) Switching current2/capacity max 0 to +60 °C 11100.0-00 11101.0-00 10 (2) A 15 (2) A 30 W VDE UL File No. E164102 EAC -10 to +50 °C 11100.0-01 11101.0-01 10 (2) A 15 (2) A 30 W VDE UL File No. E164102 EAC AC 250 V AC 120 V Approvals DC 24-72 V +20 to +80 °C 11100.0-02 11101.0-02 3 (2) A 3 (2) A 30 W VDE UL File No. E164102 EAC +32 to +140 °F 11100.9-00 11101.9-00 10 (2) A 15 (2) A 30 W VDE UL File No. E164102 EAC +14 to +122 °F 11100.9-01 11101.9-01 10 (2) A 15 (2) A 30 W VDE UL File No. E164102 EAC The level of switching current has an influence on the tolerance accuracy; 15.12.2020 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The mechanical thermostats KTO 111 and KTS 111 are two state regulators for use up to 5,000 meters in altitude, thanks to optimised air gap and increased creepage distance. By use of Push-In terminals the thermostat is wired tool-free. The Push-In terminals provide constant pressure on the wires to prevent them from coming loose (e.g. during transport).
11101.9-01
物料型号:KTO 111和KTS 111
器件简介:这些机械恒温器是双稳态调节器,适用于高达5000米的海拔高度。它们具有优化的空气间隙和增加的爬电距离,使用Push-In端子实现无需工具的接线。
引脚分配:2个Push-In夹具,适用于2.5mm²(AWC14)的硬线和1.5mm²(AWC15)的软线。
参数特性: - 开关温度差:7K(4K的公差) - 传感器元件:热双金属 - 接触类型:快动接触 - 服务寿命:已验证100,000次循环 - 最大工作电压/频率范围:AC250V, 50-60Hz - 最大冲击电流:AC16A,持续10秒 - 安装:35mm DIN导轨夹,符合EN 60715 - 外壳:根据UL94V-0的塑料,浅灰色 - 尺寸:60x33x41mm - 重量:约40克 - 工作/存储温度:-45至+80°C(-49至+176°F) - 工作/存储湿度:最大90% RH(不凝结) - 保护类型/保护等级:IP20/1 - 过电压类别/海拔高度:I类:高达5000m,II类:高达2000m
功能详解: - KTO 111(NC):恒温器(常闭);当温度上升时,接触断开,用于调节加热器。 - KTS 111(NO):恒温器(常开);当温度上升时,接触闭合,用于调节滤波器风扇和热交换器或在超过温度限制时切换信号设备。
应用信息:适用于加热器、滤波器风扇、冷却设备、信号设备等。
封装信息:尺寸为60x33x41mm,重量约40克,可变安装位置。
11101.9-01 价格&库存
很抱歉,暂时无法提供与“11101.9-01”相匹配的价格&库存,您可以联系我们找货
  • 1+134.441111+17.40200
  • 5+119.512915+15.46970
  • 10+113.1400510+14.64480
  • 25+107.3782925+13.89900
  • 50+102.1403350+13.22100
库存:12
11101.9-01
  • 1+130.87163
  • 5+116.37825
  • 10+110.16167
  • 25+104.54398
  • 50+99.41740
库存:12
