FF 018 Filter Fan 14 - 69 cfm
Very low noise
Minimal mounting depth
Functional design
Time-saving installation
Filter fans are used to provide an optimum climate in enclosures. The interior temperature of
an enclosure can be reduced by channeling cooler filtered outside air into the enclosure thus
expelling heated internal air. The resulting air flow prevents formation of localized heat pockets and protects the electronic components from overheating. The plastic used for the hood of
this filter fan series is highly weather resistant, as well as impact and UV light resistant.
Ventilating
Weather and UV resistant
Technical Data
Axial fan, ball bearing
service life min. 50,000h at 77°F (25°C) and 65% RH
aluminum fan body, plastic rotor
Connection
2 wires w/ cage clamps, AWG 14 (2.5mm²), length 4” (100mm)
Housing (filter fan and exhaust filter)
Plastic, UL 94V-0, light grey
Hood (filter fan and exhaust filter)
Plastic, UL 94V-0, light grey;
weather and UV light resistant according to UL 746C (f1)
Mounting frame
with double-sided industrial adhesive for mounting to the
outside of enclosure; certain operating circumstances may
make the additional use of screws necessary; cut-out
template included
Filter media rating
G4 acc. to DIN EN 779, filtering degree 94%
Filter material
synthetic fiber with progressive construction, temperature
resistant to 212°F, self-extinguishing class F1;
moisture resistant to 100% RH, reusable - can be cleaned by
washing or vacuuming
Enclosure ventilation using a filter fan and exhaust filter
Operating / Storage temperature
+14 to +158°F (-10 to +70°C) / -40 to +158°F (-40 to 70°C)
Protection class
I (grounded)
Protection type
IP55 (according to VDE), UL Type 1
Note: Using fine filter mat F5 increases the protection to UL Type 12 but reduces the air flow
Special features
The self-adhesive seal of the mounting frame prevents dust and water from entering the cabinet.
Functional design of the intake and exhaust fan hoods very effectively prevents direct infiltration of falling water and dust. The advantage is that the filter mat does not rapidly become contaminated with dirt
and therefore does not need to be exchanged as often.
The air channeling makes the filter fan particularly quiet in operation.
All filter fan models are also available with integrated airflow monitor.
The direction of air flow can easily be switched by reversing the axial fan.
01800.0-00 230VAC, 50Hz1)
12 cfm (21m³/h )
Air volume
Power
Average noise level
with
exhaust filter consumption (DIN EN ISO 4871)
9 cfm (16m³/h)
13W
31dB (A)
1.8” (45mm)
3.8 x 3.8”
1.3 lbs. (0.6kg)
01800.0-01 120VAC, 60Hz
14 cfm (24m³/h)
11 cfm (18m³/h)
13W
31dB (A)
1.8” (45mm)
3.8 x 3.8”
1.3 lbs. (0.6kg)
UL File No. E234324
01801.0-00 230VAC, 50Hz1)
32 cfm (55m³/h)
25 cfm (42m³/h)
15W
40dB (A)
2.3” (58mm)
4.9 x 4.9”
2.2 lbs. (1.0kg)
UL File No. E234324, VDE
01801.0-01 120VAC, 60Hz
Part No.
1)
Operating
voltage
Air volume,
free blowing
Mounting
depth
Enclosure
cut-out
Weight
(approx.)
Approvals
37 cfm (63m³/h)
28 cfm (48m³/h)
15W
40dB (A)
2.3” (58mm)
4.9 x 4.9”
2.2 lbs. (1.0kg)
UL File No. E234324
01802.0-00 230VAC, 50Hz1) 60 cfm (102m³/h)
40 cfm (68m³/h)
15W
39dB (A)
3.4” (86mm)
6.9 x 6.9”
2.9 lbs. (1.3kg)
01802.0-01 120VAC, 60Hz
46 cfm (78m³/h)
15W
39dB (A)
3.4” (86mm)
6.9 x 6.9”
2.9 lbs. (1.3kg)
UL File No. E234324
69 cfm (117m³/h)
air volume increases by 15% when operating 230VAC filter fans at 60Hz
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application.
STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
FF018/2-11/US
EMC versions and other voltages are available upon request.
Time-saving assembly and maintenance
STEGO's filter fans are easily installed by one person from outside the cabinet.
1.) Make cut-out in the cabinet wall. The cut edge of the cabinet opening should be free of
dirt, filings and grease. A template for the enclosure cut-out is included with the filter fan.
Ventilating
2.) Remove protective film from the sealing strips on the mounting frame. Press mounting
frame into the cabinet opening. The frame stays permanently in the cabinet.
3.) Electrically connect the axial fan using the cage clamp connectors. Push the unit into the
mounting frame. Affix using screws if necessary.
4.) Insert the filter mat in the hood. Clip on. Finished.
Installation sketch
To change the filter mat, simply remove the filter hood, insert the new mat and snap the hood
back again. No tools are required. Maintenance of the fan can easily be performed without
removing the mounting frame (2).
Dimensional Drawing
8.2”
3.4”
8.9”
6.7”
4.9”
5.3”
2.0”
6.2”
6.9”
1.6” 2.3”
5.1”
3.8”
1.4” 1.8”
Drilling template for mounting frame
Ø1/8” (3mm)
Ø1/8” (3mm)
7.4” (188 mm)
5.4” (137 mm)
4.3” (109 mm)
7.4” (188 mm)
5.4” (137 mm)
4.3” (109 mm)
Ø1/8” (3mm)
EF 118 Exhaust Filter
Part No.
11800.0-00
11801.0-00
11802.0-00
Mounting depth
0.6” (16mm)
0.6” (16mm)
0.6” (16mm)
Enclosure cut-out
3.8 x 3.8”
4.9 x 4.9”
6.9 x 6.9”
Weight (approx.)
0.6 lbs. (0.3kg)
0.8 lbs. (0.4kg)
1.3 lbs. (0.6kg)
Filter mat
Protection type
IP55*
IP55*
IP55*
Approvals
UL File No. E234324
UL File No. E234324
UL File No. E234324
FF018/2-11/US
*according to VDE
FM 086 Filter Mats
Filter mat
G4 (1 packing unit = 3 pcs.)
F5 (1 packing unit = 3 pcs.)
3.5 x 3.5” (89 x 89mm)
Part No. 08600.0-00
Part No. 08603.0-00
4.6 x 4.6” (118 x 118mm)
Part No. 08601.0-00
Part No. 08604.0-00
6.6 x 6.6” (168 x 168mm)
Part No. 08602.0-00
Part No. 08605.0-00
很抱歉,暂时无法提供与“11801.0-00”相匹配的价格&库存,您可以联系我们找货
