01185.1-00
01185.1-00
    STEGO
01185.1-00 数据手册
87 87 HAZARDOUS AREA THERMOSTAT REx 011 | 15 °C, 25 °C (T6) >>For areas with explosion hazard >>High switching capacity >>Compact Design >>Set temperature >>Ready-to-use with strain relief >>Temperature class T6 www.stego.de | www.stego.co.uk | www.stegonorden.se REGULATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET TECHNICAL DATA Temperature class Ex Protection type Gases Dusts 30 45 5,4 II 2 GD Ex db IIC T6 Gb Ex tb IIIC T85°C Db IP66 Ambient temperature -60 to +85 °C (-76 to +185 °F) Sensor element thermostatic bimetall Service life > 100,000 cycles Max. switching capacity AC 250 V 10 A1 Min. switching capacity DC 1.5 V 5 mA Max. inrush current AC 16 A for 12 sec. Connection silicone cable (halogen-free) 3 x 1 mm², length 1 m Connection PE 1.0 to 2.5 mm² Mounting clip for 35 mm DIN rail, EN 60715 screw fixing M5, optional widthwise mounting Casing aluminium, silver anodised Dimensions 95 x 45 x 30 mm Weight approx. 0.3 kg Fitting position variable Storage temperature -60 to +85 °C (-76 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP66 / I (earthed) Approvals EPS 16 ATEX 1 118 X IECEx EPS 16.0054X EAC 1000 95 25 5,4 T6 1 currents above 4 A affect the switch temperature difference Art. No. Contact type (1-pole) Switch temperature Switch temperature difference 01185.0-00 Contact breaker (NC) +15 °C (±3 K tolerance) 5 K (±3 K tolerance) 01185.1-00 Contact breaker (NC) +25 °C (±3 K tolerance) 5 K (±3 K tolerance) 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Compact, small mechanical thermostat offering a high response accuracy, small switch temperature difference, and a very long service life (switching cycles). This thermostat of temperature class T6 (85 °C max.) is utilised for the regulation of heaters deployed in areas with explosion hazard. The high switching performance allows direct control of a heater.
01185.1-00 价格&库存
很抱歉,暂时无法提供与“01185.1-00”相匹配的价格&库存,您可以联系我们找货
